hakuzen
- Feb 9, 2016
Ordered the IEM that shall not be named from the seller that shall not be named before all this debacle. Was very happy with it, sound wise, but the cable had a crack in it. Fine, they say they have sent a replacement, though I haven't received a tracking number.
Yesterday, while tip rolling, the whole inner part (unpainted metal thingie, with the stem etc) came out of the housing while removing a tip. Not exactly what I'm expecting from a $150 IEM. Now on to see if they deal with this in a good way or try to screw me over. I was pretty p****d off yesterday, now having to use tape in order to not have the most expensive audio item I've ever bought fall apart every time I take it out of my ear.
Tape. $150. Does not compute.
Tried wiggling the same part on the other housing, and while it's not coming out, it does move. Not very confidence inducing... Since it does move, I suppose I would be able to wiggle it loose. While I'm not going to try, using them regularly on the commute, they are going to get wiggled. I expected these to last me for many years to come, and they start falling apart after two weeks. I've had KZ IEMs that I've tried to recable (a pair of ED9), and for the life of me I couldn't get the housing open, despite trying for over an hour with every tool I could think of that I had laying around.. That is the kind of build I expect, and it's pretty sad I get it from an IEM that costs $10 or something but not this.
so sorry you are having these big issues. get the chance to look inside, to check if there is any kind of tuning besides the drivers
hope you won't have any problems with the seller to replace them (i was full refunded a package with seven items -m2 was one of them-, including return shipping costs).
i also got them before the debacle; had better luck, no issues, but expected a more neutral signature and better detail; they have very good sub-bass, but bass overall is a bit more emphasized than my liking; highs are also good enough. v-shaped, then.
