CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Received those red ones You recommended and they are exactly same as those I got with KZ ED9 boxed version! Though, there was only one pair medium size like those inside KZ ED9 box (all my 3 ED9 orders had those included). They are good and my second choice for ANV but no good news for me.
Those blue medium ones I mentioned before are still better for ANV imho. Also, blue ones have larger bore, more "tapered rocket-like" shape and silicone outer skirt is softer than red have. You must have different blue tips than on the link I shared.
Aren`t those same tips that come with most KZ IEM`s ?
They are very different if you look at the photos's on the previous page of the **** k3k you can see they are much wider, and better quality.
Those inside neck sleeves stretch easy on the kz and the sound is very different from those sort, they are also not as comfortable. Completely different I would say.
Hmmm... they do seem to have wider bore. Then they are probably those but different color: http://www.ebay.co.uk/itm/141721545729?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT&rmvSB=true&clk_rvr_id=893821896051&rmvSB=true&rmvSB=true
Yes, medium tips of those are very good (blue ones)! Best medium size tips I`ve had for those IEM`s that doesn`t need deep ear-channel insertion, like KZ ANV (I usually use smallest tips with all other IEMs). I should buy them also in red to separate channels by color.
Btw, don`t forget to post Your impressions about tips in tip-rolling thread!
Yes, medium tips of those are very good! Best medium size tips I`ve had for those IEM`s that doesn`t need deep ear-channel insertion, like KZ ANV (I usually use smallest tips with all other IEMs). I should buy them also in red to separate channels by color.
The bores seem to be slightly different shape on back lip, but almost identical in shape, but the red is slightly wider, at the bore, also the silicon outer is softer and easier to squeeze on the red.
It would be cool to have the same tips in red/blue tho for left and right.
