cooperpwc
- Nov 20, 2006
This is interesting. So if I understand: you are saying that even before I get a balanced DAC (still sometime down the road), if I recable my 600 ohm DT880s (which qualify as hard to drive), I will see an actual performance improvement by comparison with the current unbalanced cabling, i.e. the recabling alone allows twice the voltage swing with the MK VI! If so, that could be an interim step...
Originally Posted by philodox /img/forum/go_quote.gif If your source is not balanced, but your amp and headphones are, you may miss out on some sonic benefits of a fully balanced setup, but will still have twice the voltage swing and current as compared to the same amp unbalanced... so hard to drive headphones will still benefit here. |
