Head-Fi: Covering Headphones, Earphones and Portable Audio
Support Head-Fi by starting your Amazon.com shopping by clicking here
Follow headfi on Twitter!
Follow Rocky Mountain Audiofest (RMAF) on Twitter!
Head-Fi Is Sponsored By:
Featured
Head-Fi's Sponsors
(Premier Sponsors bolded)
Featured
Can Jam '09
(2009 International
Head-Fi Meet)
Impressions,
Reviews, Photos
Can Jam '09 graphic
courtesy of Edwood
Click on the links below
for Can Jam '09 photos,
impressions and reviews:
blubliss 1, 2, 3
dallan 1, 2, 3, 4
santacore 1, 2
nhat_thanh 1, 2
vpivinylspinner 1, 2, 3
amb 1
augustwest 1
eaglejo 1
johnsonad 1
shellylh 1
Jon L 1, 2, 3, 4
Germancub 1
zippy2001 1
IPodPJ 1
bhd812 1
Edwood 1, 2
abellaw 1, 2
minidiscs 1
atothex 1
HighLife 1
achristilaw 1
SiBurning 1, 2, 3, 4
SiBurning 5, 6, 7
LFF 1
Iron_Dreamer 1
doping panda 1
morphsci 1
ironbut 1
shaizada 1
jasper994 1, 2
jp11801 1
Uncle Erik 1
drubrew 1
(More impressions/photos
still being added.)
Head-Fi Blogs
and Facebook
Check out Head-Fi's new
Blogs section.
Featured Head-Fi Blogs:
Jude's "Take My Word"
 From Japan - by Sasaki
Currawong's Blog
Start your own Blog!)
Attention
Facebook Users
Join the official
Head-Fi.org
Facebook Group
Featured
Head-Fi's Sponsors
Featured
  #6001 (permalink)
Old 09-03-2008, 04:23 PM
Pricklely Peete's Avatar
Default
Originally Posted by fugimax View Post
I'm confused on exactly how this would end up being wired. You cut the neutral / primary wires and insert the blokker in there?
Also, do you think there's a place for this to sit / mount in the Zero case?
Originally Posted by LeBuLLeT View Post
Yea I am confused like fugimax. First I am going to try a good power cable then if that doesn't show an improvement then I will get this "blokker."
Guys it simply connects off the IEC Neutral connection (in between the N terminal and the neutral wire to the toroid primary inside the Zero) in series (google series connections) as follows......here's the direct quote,
Just connect the red wire in series with the neutral of your mains supply, blue wire to transformer primary side and kill DCv dead. Also removes destructive harmonic content created by other electrical devices loading your power matrix. Most AC supply has some DC offset present. DC is the enemy, robbing a power transformer of efficiency and often making it hum. Blok it, and the transformer can do its job, Sound improvement can be major depending on your line conditions.Small enough to fit in most chassis. 5cm x 5cm x 2.4cm. 3A/240V.
It sounds far more complicated than it is. You could even do this outside the chassis as long as the wiring is where specified. It should fit in beside the toroid though quite easily. The 240V 3A rating makes it suitable for worldwide use.
Peete.
__________________
Cans :HD650, AKG 240M (HD650 DIY cables SE and Balanced)
Desktop amps : LD MK III (6H30P-i DR's + DIY mods, Jaycar DIY kit amp (major DIY mods), 2 X Audio-gd Compass (test prototype,final version), Audio-gd C-2C W/ Stepped pot Upgrade, Audio-gd Phoenix SS balanced preamp/headamp.
Transports: Auzen Prelude PCI 7.1 SC/ASIO native driver using Media Monkey (all EAC ripped FLAC/Wav), Vanguard CDM12 Pro (BNC mod), HK HD720 (completely upgraded), Audio-gd CD7 Transport.
Sources: FrankenDAC DIY 24/192 dac (HDAMs/Teflon/PIO cap mod), Compass DAC, See Corp Vintage UK TT(Mission arm/Ortofon OM20S MM cart), Yaqin MS12B tube phono preamp, TEAC V530X Tape deck, Audio-gd Reference 1 DAC. C2C DIY pot mod http://www.head-fi.org/forums/f6/ste...1/#post5846722
  #6002 (permalink)
Old 09-03-2008, 04:33 PM
RedSky0's Avatar
500+ Head-Fi'er
Default
This may not be the best place to ask, but is there a guide out there to op-amp rolling? I'm not quite certain what it physically involves, and how technical it is. Sorry if someone's asked this question already, but going through 600+ pages is impossible.
__________________
Headphones/IEMs: PX100 (earpads butchered), AD700, iM716 (cable murdered), HD600, Proline 750 (sold), ER-4P/S
DAPs: Xclef HD-500 (sold), iRiver H320, Creative Zen 4gb (sold), Cowon D2 (sold), Sansa Fuze, Apple iPod 5.5G 80GB
Amps/DAC: MisterX Mini³, FiiO E3, FiiO E5, audio-dg Compass
  #6003 (permalink)
Old 09-03-2008, 04:40 PM
Default
Originally Posted by dario View Post
But how much cost the power supply? And it can be changed "plug and play"?
I think also the if we know how much power require the opa627 and lt1364 we would do a much more realistic analysis, becouse if the opa rate is 15v they would require a maximum of:
0,66W for the Sun
0,84W for the Earth
If we know how are hungry the "standard" opa we can understand how much is the difference...
Unfortunately this modification comes under intermediate to expert level on the difficulty scale...not because it's actually hard to wire up and solder in...because you need to know what your doing and have a digital multimeter and other tools necessary to do the job properly...which means measuring things with lethal voltage levels applied.....not safe in other words for a beginner who has trouble finding the opamp socket.. ( I don't mean anyone in particular...it's just an example).
The wattage isn't the real concern...it's the current delivery capability of the stock toroid and volt regs...they are close to max ratings with 1 HDAM in the dac section and LT1364's in the H/Amp section.
If I had to guess what the draw of the stock Head Fi deal opamps are I'd say no more than 50 - 60 ma in total...if that.
Once I get my reg/transformer kit and install it I'll post pics through Pench and instructions how I did it for anyone else that want to try it. The cost from Welborne labs for this kit (15 V DC @ 1 Amp ) is 75US including shipping....so it's not cheap. The actual volt reg board itself is rated to handle a maximum of 3A so it's got tons of headroom to run 3 HDAMs easily....The percentages work out to 1/9 th loading on the 1 amp transformer and about 1/40 th load on the reg board max capacity. If I have made a mistake...please correct me...it's off the top of my pointy , cement filled head
If a person were to build the reg from scratch and source the transformer I'm sure that cost would drop to 30US or less...but that is beyond my abilities at the moment (give me a few months ).
Peete.
__________________
Last edited by Pricklely Peete; 09-03-2008 at 04:43 PM. Reason: grammar ...spelling...the fun of it all :D
  #6004 (permalink)
Old 09-03-2008, 04:42 PM
100+ Head-Fi'er
Default
Now the OPA works in +15 and -15, i.e. 30V dc.
multiplying the 30 by 130mA, we have, 4W for the OPA alone.
Beside OPA, there is DAC , receiver chip, logic circuit, relay (each relay 50mA !), other little component that drains power as heat.
So it looks like 3*OPA is more or less confirmed to drain the the tranny hard.
__________________
HTPC -> [BlueJeans Fiber Optic] -> DAC-19MK3 -> [ CAST] -> CIA-400 -> [ VDH Goldwater ]-> KEF-CRESTA10 modded
  #6005 (permalink)
Old 09-03-2008, 04:45 PM
Default
google "opamp rolling"...I'm sure that will help. Also go to page 1 and look at the pics and info on most of popular types used in the Zero.
Peete.
__________________
  #6006 (permalink)
Old 09-03-2008, 04:53 PM
Default
Thanks CC...that would explain the loss of bass and other SQ issues I ran into with Earth and 2 SUNs config a few days back...and reported soon afterwards...
Interesting... Hi speed regs wouldn't solve the fundamental issue of current starvation would it CC....?
Do you concur with my assertions thus far on the matter (reg/tranny kit solution) ?
BTW thanks a million for filling in the blanks , your info is invaluable to my understanding of things (limited as it is) !!!!!!
Peete.
__________________
  #6007 (permalink)
Head-Fi'er
Default
Being that the 3x HDAM probably won't happen for me anytime soon (I'll let Peete experiment, first!) where's a good place to pick up some LT1364s?
I'll probably just experiment for now with Earth v. Sun and potentially picking up that blokker if I'm hearing line noise once my Zero comes.
__________________
Home Setup: Harmon-Kardon T60 Turntable / Airport Express + AMC DAC8 --> Outlaw RR2150 --> Custom Meniscus Audio speakers
Home Setup #2: iMac --> Zero DAC/Amp (2008) --> ATH-ESW9's
Work Setup: Mac Pro --> Compass --> Denon AH-D7000's
My Projects:
Relamping a Yamaha CA-810
Polishing a Turntable Platter
  #6008 (permalink)
Old 09-03-2008, 05:01 PM
DaMnEd's Avatar
100+ Head-Fi'er
Default
Directly from linear, you can get free samples, just search for samples/linear on this thread.
__________________
PC (WASAPI) AMB/Mr.X γ1 (W.I.P) Pure Silver m-RCA D.I.Y Millett Hybrid MiniMAX D.I.Y (W.I.P) / AMB Mini³ D.I.YSennheiser HD-650 / Grado RS-80
  #6009 (permalink)
Old 09-03-2008, 05:16 PM
Head-Fi'er
Default
Thanks, samples requested. I was at least expecting to pay ... geez!
__________________
My Projects:
  #6010 (permalink)
Old 09-03-2008, 05:27 PM
Penchum's Avatar
Default
Originally Posted by Pricklely Peete View Post
The wattage isn't the real concern...it's the current delivery capability of the stock toroid and volt regs...they are close to max ratings with 1 HDAM in the dac section and LT1364's in the H/Amp section. Snip-O-rama!
Peete.
I totally agree with your assessment of this PP. I just did a test to confirm how many HDAMs it takes to finally observe the drain on resources. It worked out like this:
Earth in DAC, LT1364's in headphone amp = Plenty of resources, headroom.
OPA627s in DAC, 2 "Sun" HDAMS in headphone amp = Resources peaked, headroom questionable.
Earth in DAC, 2 "Sun" HDAMS in headphone amp = Resource drain obvious, no headroom, bass punch gone.
So, the third HDAM is one too many for the resources on hand.
This isn't necessarily a bad thing. Keeping "low cost", "simplicity" and "flexability" in mind, one HDAM in the DAC section, giving you a super clean and dynamic signal, and your favorite Opamps in the headphone section, will result in some serious quality sound, while keeping the Zero in a "happy camper" operating state. When you think about it, it really isn't a trade off at all. Having the superior DAC signal is the best possible upgrade overall. It gives both the DAC output (RCA's) and the internal headphone amp an improvement at the same time. This also leaves room for you to further customize the headphone amp with different Opamps, to match with personal tastes and differences in headphones.
__________________
Full Reviews: Zero DAC/Amp LD MK1 LD MKII LD MKIII LD MKIVse LD MKV DIY Bull Plugs
Mini Reviews: Volex 17604 Power Cord X-Fi ExpressCard Notebook
Zero Mods Links: Zero Alps Pot Mod Zero LED Mod
My Integrity: Who am I
I am an independent audiophile, who writes impressionistic reviews ONLY for the benefit of the readership. My impressions, opinions, results and conclusions are my own. Audio is my hobby and my passion.
Due to medical issues, I've had to scale back my participation here at HeadFi. I'm hoping it doesn't last too long. Thanks for understanding!!
  #6011 (permalink)
Old 09-03-2008, 05:36 PM
Head-Fi'er
Default
Finally got my tracking number for the Zero DAC/AMP. Will be ordering a set of Denon AH-D2000's on Friday to go with the Zero.
Looking forward, as the best headphones I have ever used was a $25 Cyber acoustics headset. lol
  #6012 (permalink)
Old 09-03-2008, 06:18 PM
100+ Head-Fi'er
Default
I do not think you will be happy about D2000 with zero headphone Amp.
PP: Computer PS test failed. It looks like just get right volt and current is not enough.
My power board is hold LA. I do not know how can a shipment from China to Canada can ever be hold in LA for 1 weeks.
__________________
Head-fi feedback
Ebay
Paypal Account: Canadian - Verified (24)
  #6013 (permalink)
Old 09-03-2008, 06:22 PM
100+ Head-Fi'er
Default
but the zhaolu has a sufficient power supply for a 3 hdam configuration?
I ask becouse I will have 3 sun hdam in the next weeks and I would want to use all...(I have not bought the zero yet than I have free choice)
  #6014 (permalink)
Old 09-03-2008, 07:18 PM
Default
Which one the 2.5 or 3.0 ? It's a different amp and I don't know anything about it. The 3.0 is 300 US and I don't know what the 2.5 cost...200US is a guess.
Can't tell by looking at it from pics...the transformers are covered up and there is no real details posted unless I need to find a better source page.
100VA is a pretty standard size power supply rating for most compact DACs of this class. I don't see the Zhaolu packing anything bigger than that in that size chassis...I could as always be wrong
Peete.
PS LC by the way used to work for Zhaolu IIRC. That's why the two are similar in design and philosophy...with the Zero being the lesser cost option with the better H/Amp in it. the 3.0 has no headphone amp I think...so that's no good for you ? Can you check that dario please...thanks. I've got to look up specs on the Zero's stock volt regs and see it there is better hi speed, higher current parts. The toroidal transformer has to be uprated to maybe 300VA...need to check all this out and gets prices and such...
__________________
  #6015 (permalink)
Old 09-03-2008, 07:20 PM
Default
Figures eh Alex....oh well it was worth checking out at least. Hmm, in LA...WTF ?
Peete.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Head-Fi.org
