If people don't want to read 100+ pages..... I will try to summarize below OR Skip to
Newer generation BT Technology (2024+) section below
Everyone loves and hates Bluetooth, why? too many standards, formats, codecs and devices all of them almost incompatible with each other or not supporting the right BT Codec. This is probably the best thread on the entire internet to try and work around or make some sense of the issues.
Example of why Bluetooth Wireless Audio & technology is so confusing and difficult;
I just bought Sony XM5 headphones but they support LDAC "high quality Audio" Codec, but wait my expensive 2023 TV does not support LDAC!?, Wait... my latest Windows 11+ PC does not support LDAC also...wait my Mobile phone only supports aptX not LDAC,
what is going on!
Another example; LG OLED TVs more recent models support aptx-HD Bluetooth codec designed for high resolution Music listening. Did LG forget people actually use their TV to watch rather then listen to music? They should support aptx-adaptive for TV watching or better yet LE audios LC3+ for better lip-sync performance.
Why can't I just enjoy Bluetooth devices and get on with it?
-Sure nearly all Bluetooth devices can default to older SBC codec or AAC etc and just work but then you can get lower quality audio or performance (Latency issues ie gaming delay/movies lip sync issues), so choice is yours.
To get a better understanding these are good reads
understanding bluetooth codecs
The best Bluetooth headphones can be ruined by a simple, elusive setting (applies to all Bluetooth devices, Phones etc)
Whathifi list all the Bluetooth Codecs and future ones
Top BT Adapters going or the ones that appear to work best for getting the best Bluetooth Connectivity with as much BT codecs
but not all (AptX Codecs, LDAC etc) between our Bluetooth devices ie Windows 10/11+ PC, Linux PC, android/WebOs TVs/Android devices and Boxes/Mobile phones, Amps/Dacs, Portable Music players, etc
For Windows but
may support Linux/Android/Mobile Phones/Games Consoles (Please check that is supports your devices)
KB8 and KB8P adapter
KB9 and KB9P adapter
Creative BT-W3,BT-W4, BT-W5 adapters (BT-W5 and BT-L4 confirmed working well enough with Nvidia Shield with adptx adaptive but has some crackles/audio drops also
recently discovered and props to
@anonnexus here mentions 3 quick button presses (on the creative dongles) can adjust between AptX Adaptive HQ and AptX Adaptive LL this could work on other Creative BT dongles with a button on it, Tested on my Creative BT-L4 LE audio dongle and it does work also and switches to low and high modes.
Avantree DG60p adapter
Sennheiser BTD 600 adapter
Creative BT‑L3 and BT-L4 Audio Transmitter with LE/LC3 Codec support (only available with Creative Zen headphones)
Creative BT-L3 confirmed working well with Nvidia Shield (slight audio drops though) with LE audios L3+, 20-30ms latency so
best lip sync performance.
Creative BT‑L3 and BT-L4 Audio Transmitter with LE/LC3 Codec support (only available with Creative Zen headphones) (May work on other LE devices? see
here)
FlooGoo FMA120 BT dongle with aptx-adaptive and LE audio support
here and mentioned
here
Avantree ProLink BT dongle with 3.5mm/2.5mm and USB connectivity with aptx hd/adaptive and LE audio/aptX-Lite
here
Eppful AK818 with LE Audio
here (May+ 2024 release) (double check the specs these may support apx and other BT codecs)
Avantree as70p LE receiver dongle
here (May+ 2024 release) and specs
here (double check the specs these may support apx and other BT codecs)
Eppfun AK3040 Pro Max USB C transmitter (New Qualcomm S3 & S5 Gen 3 platform standards) with LE works and possibly? Aptx Lossless. See
here
For TVs/Android devices/boxes (May use Optical/3.5mm headphone jack/BT mode- again check it supports your device)
***Edit** (My personal choice) Artic Steelseries Pro Wireless headphones, currently my daily drivers due to 2.4ghz wifi wireless break out box supporting optical input/others. Gives best latency/lipsync performance to date but only via optical input. Works perfect for normal TV watching, Nvidia shield pro 2019 and PC check my review linked at bottom.
eppfun 3040R Pro Bluetooth Receiver (
LDAC/APTX/APTX LL/APTX HD/LDAC/AAC/SBC)
eppfun AK3046D Bluetooth 5.2
eppfun AK3046C Bluetooth 5.2 Transmitter Receiver
eppfun AK8675 Pro aptX-Adaptive
eppfun bluetooth 5.3
LE audio transmitter receiver for audio (only supports LC3
Not LC3+, review link at bottom)
Avantree Oasis plus
Avantree Orbit Pro (pre-order as of September 2023)
Avantree DG60p adapter (works with Nvidia Shield Pro 2019 with LDAC)
Creative Zen hybrid Headphones + New BT Adapter with BT 5.3 and
LC3+, LC3+ULL (ultra low latency 20ms) Codec for Gaming/Movies Now available
here
Sony pulse elites review
here
Newer generation BT Technology (2024+) section below BT adapters/Receivers and Transmitters with latest BT Technology
Most popular:-
Floogoo FMA120 review
here,
here also important information
here and another mini review
here,
here
Eppfun AK3040 Pro MAX mentioned
here and
here and review possibly?
here,
here
FiiO BT11 mentioned
here and
here
iFi ZEN Blue 3 mention
here (should support optical in, Audio in, PC usb input and more connectivity for TV, Consoles, PCs etc)
Others:-
LE audio church pack review
here
slash-t BT dongle mention
here
PyleUSA BT review
here
Prozor BT review
here
Avantree LE receiver mention
here
Eppfunn LE snapdragon adaptor mentioned
here
Mingzhe 5.8G Wireless In Ear Monitor System Wireless Review with 5.8 Ghz Tx/Rx for low latency gaming with iems
here
Xpan Snapdragon Wireless wifi compatible Phones, ear buds, headphones and receivers/transmitters:-
N/A
(July 2024 rumour from group member suggest Xiaomi May be the first one to adopt XPAN into their products mentioned
here)
Probably 1000+ other devices but you can google for the above products to get specifications but I would recommend searching this thread or headfi forums for more info on specifics and issues you may face since its been repeated numerous times on this thread.
Usually
aliexpress have these devices for sale just search for the model ie KB9P, Amazon or ebay also have them but under different brands and companies sometimes offering faster delivery usually cost more though, eppfun is one such company there all over amazon and have a store on aliexpress.
Its almost trial and error if they work or work well without cracking/popping or may just not work with your BT headphones, phones, IEMs, buds, TVs etc
Please note even this post/Info is already out of date by the time you read it since manufactures/Organisations release new BT standards and Codecs every year and compete with each other and make it even more
confusing then it is. I also recommend reading this thread or the last 20-30 pages if you can to keep updated.
Other important links:
Bluetooth troubleshooting checklist - Manufacturers are free to use or copy this list
What I would like Manufacturers using Bluetooth technology to do in their own products before shipping
Firmware updates, Bluetooth Software for KB8/9 and more
here
How to get LDAC and Aptx-HD Codecs and better options in Windows 10/11
here and main site
here (won't work always or support all BT modes/codecs though)
What happen to AptX-LL? and what is AptX-Adaptive
here
What is LC3 and LE Audio codecs
here also
here and
here(has done real world testing in gaming/latency test )
What is Aptx Lossless
16bit vs 24bit and bitdepths explained
here
HeadphoneAddict Bluetooth guide
here
Soundguys Understanding codecs (Updated Aug 2023)
here
Soundguys why LDAC is not high resolution
here
Soundguys why Bluetooth Latency is still a problem
here
BT LE, LC3, LC3+, LC3+HR breakdown
here props to @011111
Snapdragon Sound with aptX Lossless technology mentioned
here, a device already supported
here
Reviews on some Bluetooth Chinese Transmitters/Receivers
eppfun AK8675 Pro Bluetooth 5.2
Avantree DG60P 5.3 USB receiver (2023 edition) mini review
eppfun AK3046D Bluetooth 5.2 Qualcomm aptX-Adaptive HD Transmitter
1Mii Bluetooth 5.3 Transmitter Receiver for TV to Headphones (Amazon review)
Arylic B50 BT transmitter/Receiver YT review and Some after thoughts I had
Avantree Relay review
Creative BT-W5 and BT-L3 reviews
here
Creative Hybrid Zen BT headphones with BT-L3 adapter review
here
Creative X5 desktop amp with USB A BT Transmitter/Receiver mode works with Creative BT dongles review
here
Eppfun LE audio 5.3 BT transmitter/Receiver from ali express review
here
Artic Pro Wireless Steelseries Wireless 2.4ghz Wifi wireless headphones with docking station with optical input review
here (Excellent for TV/Gamers)
Sony Pulse Elite 2.4ghz Wireless headphones review
here
Latency Checker app/website props to
@helmutcheese here and direct link
here and Lipsync cartoon real world test
here
Latency better Real world test video
here its a youtube video titled "A Closer Look to the Max: Trump Fraud Trial" by late night with seth meyers
where at the start of the video he rapid talks current news affairs, excellent test for lip sync which can be done via YT app on any device (phone, TV, cable/sat tv etc)
Latency benchmarks and test with Sennheiser MOMENTUM 4 hps and top end BT dongles
here props by
@klaboor
LEAudio latency test - LC3+ 20-30ms and LC3 50-60ms
here
Snapdragon Sound
Qualcomm S7 SoundPlatform, Snapdragon Wifi for Next generation Wireless sound for 2024+
AS Drflimflam member ran some optical vs usb latency test (Gamers/Movie watchers)
here (Optical much better latency)
Ferrite Cabling and optical (hdmi/audio/usb) cables are better for reducing EMI/Noise and interference for general connectivity and BT mentioned
here
Soundguys What is Snapdragon Sound article (November 2023 article)
here
Will Snapdragons XPAN/S7 wifi wireless Audio work on Existing wifi networks and Routers? Yes it will see
here
Qualcomm confirms Snapdragon X Elite PCs will launch with the "next version of Windows" in June
News spotted
here
TechRadar's What is Snapdragon Sound article
here (updated May 2024 hardware compatible list)
cme-iwa-technology preview mention
here
In case I have missed mentioning names or giving props, thumbs up to all! Wireless Audio is only getting bigger and better so it is becoming difficult to keep
on top of technology.
