Wanted to know for a soundcore q30 on desktop the kb9 plus or another that I found thats the same, but has an antenna?
Dont really have that much money and I am having constant crackling from the computer, on my tablet or phone it doesnt happen.
Also do these also work as a normal bluetooth adapter?
This is the link of the one with an antenna
CSR BT 5.2 Audio Transmitter aptX LL HD 24 bit Adaptive Low Latency Multi-point With Mic Wireless Adapter For TV PC PS4 PS5 Xbox https://a.aliexpress.com/_mKAvltu
Due to your above comment, I looked at it again and it does indeed carry over the settings from my PC to my phone so thanks for that.
I am 99% sure it did not a few weeks ago and others were asking for this feature, but it did get a new Audio driver update the other day (not including the big FW/App/Audio Driver update we got a few months back).
Hey thanks for the answer, the adapter I have now is connected with an extension with no interruption to where I am, also tried a usb 2 port and still the same.
It seems to be weak signal or noise it happens more some times and not always.
Was hoping one of those adapters would give me better range/performance as they have newer bluetooth and one has an antenna.
My bluetooth adapter is 4 aomething I believe.
USB Audio Player Pro is one of the first (along with Neutron) music app that bypasses the internal android sound mixer that limits output to 48khz and then 192Khz. With UAPP you could hear upto what your USB DAC could support in bitperfect (if chosen). Thru the app, you could access your network (ftp, smb, WebDAV), Tidal/Qobuz, Internet Radio, ShoutCast radio, Cast to, or an UPnP/DLNA device. You could use your device too as a UPnP renderer.
With BT-W5, it will be treated by the app as a USB DAC. Sadly before the update there were issues (garbled sound). Now ifixed with the latest update.
Since I have multiple sources and format (like above a DSD128 file). I set DSD playback to PCM. And set max sampling to 96khz. As seen on the pic. The program says source file is DSD128. BUT DAC is playing at 96Khz (max of BT-W5).
I own UAP Pro and know about the Android hard limit of 48k but do not really use it other than when I was testing with wired earbuds for 24/192k due to the 3rd party driver that bypasses that limit.
I can bypass it via any of the USB Dongles I have tried in PowerAmp Pro and even later on when I subbed to Amazon Music HD (they must have updated as claimed they do not support Ext DAC's) and this is on phone and Nvidia Shield.
USB Audio Player Pro is one of the first (along with Neutron) music app that by passes the internal android sound mixer that limits output to 48khz and then 192Khz. With UAPP you could here upto what your USB DAC could support in bitperfect (if chosen). Thru the app, you could access your network (ftp, smb, WebDAV), Tidal/Qobuz, Internet Radio, ShoutCast radio, Cast to an UPnP/DLNA device. You could use your device too as a UPnP renderer.
With BT-W5 it will be treated by the app as a USB DAC. Sadly before the update there were issues (garbled sound) now its fixed.
I have a Qudelix 5k which shows the transmission rate in the app. It never goes above 279 kbps with the BTD600 and the BT-W5 shows 420 kbps in quality mode.
I'm still fighting with pops and cracks for BT-W5 and BTD600. I ordered another USB 3.0 and USB 2.0 extension cables. My motherboard doesn't have USB2.0 only ports, but I can switch USB 3.0 functionality OFF in BIOS so all ports will become USB 2.0 standard. The only pure USB 2.0 port is internal so I try to use them. I ordered PCI-E USB 3.1 controller with USB-C output since BT-W5 is primary USB-C. I'll test everything next week.
BTW we are all talking about small portable dongles, but is there anything aptx adaptive capable in form of desktop DAC? Like this FiiO BTA30 PRO for example. I found Pro-Ject Audio Systems Phono Box E BT5 but it does only phono and line inputs and I would like to have at least USB input like any PC DAC. If anyone knows about anything, please let me know.
