SP Wild
- Dec 29, 2009
As I understand it.. The RSA Amps (a couple of them anyway) can take the SE output from something like the Mojo and internally separate the signal into two opposing signals (isn't the differential... unless I have the concept completely wrong, and is likely the case) that can then be output via a balanced connector. It may not be "fully" balanced throughout, but this workaround still provides a workable balanced solution I would think. I was just wondering if there was anything else out there that does something similar.
Most balance amps can do something like this. My AudioGD Phoenix does, as does my WA22... Actually the WA22 is balaced but not differentially signalled... Just to confuse you some more.
