ytisawfulnow
- Apr 23, 2011
How would i go using the E9 or E17 with an AV Receiver?
I currently own a pair of ATH-M50 but i've noticed the Q701 have come down in price a lot on Amazon.com, from what i originally thought were $400 to $240.
Anyway, here are my questions:
Is it worth buying these if i already own the M50s? do they sound significantly better?
Which amp should i use to drive them? Under $100 preferred, willing to go up to $200 if i HAVE to.
How badly do they leak sound? my room is right next to my parents, door shut, i listen about 1/4 way on speakers, half way on iTunes, air con on most of the time.
If i have anything else i forgot to ask i'll post later.
I listen to mainly electronic music and rock music, also instrumental and ambient stuff, some hip hop... I don't like a lot of bass, M50 have about the right amount of bass for me, maybe a little too much now that i think about it.
I will also be using them for movies and gaming as well.
My source is an AV Receiver on a cheap (around $300) Sony home theatre system (so obviously i will need an amp)
I think that's about it....
yeah.
The Q701's are not for you.
Yes, they're very high quality.
Yes, they sound much better than the M50's.
But they're fully open headphones; others near you will hear them playing.
They need an amp. A FiiO will do, but more than many headphones they
benefit from high quality amplification.
Bass is not their strongest attribute in any event; their real strength is in
their massive soundstage. Electronica and rock don't show them at their
best, especially without a quality amplifier.
In short, for $240 or so you can get headphones that are much more suitable
for your listening preferences..
I doubt they would leak through a closed door into another room enough to bother anyone. And I think electronic music really benefits from a nice open soundstage. I also think they're bass is very good for an open headphone.
But if he wants more isolation and more bass he can look at the D2000, K550, or A900x.
This is my receiver:
http://esupport.sony.com/US/p/model-home.pl?mdl=STRKG700&template_id=1®ion_id=1&tab=manuals#/manualsTab
lol 6ohms
