I would say that overall the Woos might pop up on a fairly regular basis but not any particular model. But the WA6 might be the most popular one so there you go. I picked up my WA22 in the FS forum and there were 2 or 3 of them available at that time.
Woo Audio Amp Owner Unite
- Thread starter dannie01
- Tags
- akg-k701-studio-headphones beyerdynamic-dt-880-pro-600-ohms grado-statement-series-gs1000i-headphones schiit-valhalla sennheiser-hd-650-headphones wa3 woo-audio-2 woo-audio-wa-6-se woo-audio-wa22 woo-audio-wa3 woo-audio-wa5 woo-audio-wa5-le woo-audio-wa6 woo-audio-wee-electrostatic-energizer wooaudio wooaudio-wa7-fireflies
Silent One
What silence said... then nothing.
- Aug 9, 2010
Any Woo Audio owners have a run at using a linear regulated power supply or battery supply w/ W4S DAC-1's & DAC-2's?
mikemalter
Any Woo Audio owners have a run at using a linear regulated power supply or battery supply for their W4S DAC-1's & DAC-2's?
You mean like a PS Audio power regenerator?
Silent One
- Aug 9, 2010
Not quite that extensive. Rather, an external supply or battery supply. A linear regulated supply brought my EMU-0404 added depth; weight, to my presentation. From what I hear, Bolder makes great linear supplies but a lil' out of my reach. Looking to kick sonics a bit higher with the W4S shoe-box!
Do you think that a dedicated computer UPS to isolate the power would make a difference?
WarriorAnt
- Jan 9, 2009
I think having the computer on a different power outlet helps. I use an APC XS 1500 for my Mac on a separate outlet. Also the battery backup seems to have extended the life of my external drives.
I have my gear on a separate line. Soon I will be looking for an electrician to install a separate 20 amp line from the breaker box just for the rig to juice up on.
I meant dedicating a separate UPS for the DAC.
Silent One
- Aug 9, 2010
Not sure. But what I'm seeking comes before a UPS and other auxiliary components. I'm searching for a dedicated Linear Regulated Power Supply or a LiFePO4/SLA battery solution in place of the DAC-1's internal power supply which is good, by the way. W4S/Cullen does good internals. I just want to kick it up to the next sonic level!
![popcorn.gif](http://files.head-fi.org/images/smilies/popcorn.gif)
For example, I'm reviewing the option of running a 12volt cable out of my Mac bypassing the internal SMPS and connecting directly to battery power. Or a custom Linear supply for the Mac. I simply want to do the same for the DAC-1.
Silent One
- Aug 9, 2010
You got it good! I can't tamper - staying as a guest temporarily in another's home. I will plug-in my Woo (analogue) into a separate outlet soon, though...
WarriorAnt
- Jan 9, 2009
How would you achieve this with eW4S DAC?
Silent One
- Aug 9, 2010
What, the Linear supply or battery? Either would depend on the vendor's design. I really like what RWA, Mach2music & PiAudiogroup are doing in this light to take things off the grid. And makers like Bolder for Linear supplies...
The one item that seems to be Mi$$ing?
![biggrin.gif](http://files.head-fi.org/images/smilies/biggrin.gif)
dminches
- Jan 21, 2007
I didn't think that UPSes are really that good for audio equipment with respect to clean power. I see them as more for protection than anything else.
mikemalter
I've heard the same thing.
Xcalibur255
- Feb 4, 2008
Does the stock unit have a switching PSU? I've heard lots of arguments about switching vs. linear on the tripath side of things. There is a general feeling that switching supplies are considered inferior, but if the unit is well designed and is regulated this is almost entirely untrue. The most common comment I see is linear seems to add a bit of weight and drive to the music, but this is in reference to an amp and not a DAC.
I never tried the wall wart switching PSU that came with my VDA-2. Since I ordered the upgraded linear supply from day one that is all I ever plugged into the unit.
Silent One
- Aug 9, 2010
Depending on a DAC's design (analogue or switching) it too, can have the same benefits of more weight and drive. This is the same benefit I got when I dumped my wall-wart for a linear regulated transformer supply on my EMU-0404 USB Interface (DAC) - night & day! Additionally, the Mac can benefit from both Linear & Battery supply outside its chassis.
Total: 10 (members: 0, guests: 10)
