shipsupt
- Nov 22, 2010
Just wanted to say thanks for the replies to my question about the high and low gain outputs on the 6SE. Supports and adds to what I read previously about the specific issue of the HiFiMAN line up. My brief first listen last night told my ears more of the same!
I was still curious about how gain is actually adjusted in this unit and what effect it actually has, but after some more research it seems to me that power output is not changed, gain is essentially just a volume control. If that's the case... I've answered my origial question.
Thanks,
Chris
Don't know about the HE-5's but the HE-6 using my max WA6SE will not properly power the HE-6's. Yes you have enough volume but you will never hear what the HE-6 can really do. The only headphone amp that I know about that can properly power the HE-6's is the WA5/LE from the low imp or the high imp and also the XLR jack in the WA5.
The HE-5 are louder out of the high-gain plug for a given attenuation step than out of the low-gain plug. IMO, the difference isn't enough, and if I cared to spend the shipping and labor cash, I would probably send my unit back and ask for the low-gain plug to be even lower. This is using AFAIK the quietest tubes as well (6EW7). Other tubes, like the 6CY7 are really too loud; I don't know for certain, but I bet with those tubes a HE-6 would work just fine out the high-gain on a WA6SE and hopefully I get a chance to test this one day.
I'm sure that the info is in this thread somewhere, but I believe that 6SN7 tubes w/ adaptor would put even more volume through the amp.
Well, I can't comment on the subtleties of the sound that may be missing, but to my ears the WA6SE drives my HE5-LEs beautifully. They are easily the least efficient set of cans in my collection, but I have a pretty hot source so I have no problems with gain using 6de7/6ew7 tubes. I find the presentation to be very, very good compared to my VHP-2 or out of my backup preamp's headphone jack. That said, I have not heard the HE5-LEs on a more powerful amp.
In any case, I have no doubt you will find the 5s are a pretty sweet match with your amp.
