If you remove the Monster power conditioner from the equation, do you still get a hum? Is it a steady hum, or does it cycle?
Thanks for the suggestion, but no, it's still there no matter what. I've disconnected all sources, taken the power conditioner out, etc. Even if I just plug the Woo straight into the wall with nothing else connected except headphones, there is still a very faint hum.
It is steady and continuous. No cycling. It is there no matter what position the volume control is in. And actually, now that I've checked it out and listened carefully, adding the 3 to 2 pin adapter does not eliminate it. It's still there. I've tried changing power tubes, and rectifiers, but it's always the same. I think it's probably normal.
I did have an extremely loud hum a few months ago, and it was caused by me, using 6FD7 tubes briefly, and my amp was not new enough (February 2010) to have been able to handle those tubes. I sent it in for repair, and to have the modifications done so it could use those tubes. When I got it back, it had been repaired, but the loud hum was still there, so I had to send it in again. Jack Woo said they had checked it after they did the repair and mods, and that it was fine before they shipped it back to me.
After sending it in the 2nd time, it came back working fine, like it is now, but I have noticed this very faint hum for quite awhile, so it may have always been there. Or, changing some of the parts inside to allow the amp to accept the 6FD7 type tubes may have introduced this hum; I don't know. Actually, I didn't even like the 6FD7 sound, and haven't used those tubes since.
As I said, this hum is very faint, and if I'm not listening for it, either between tracks, or when the music is paused, I can't hear it at all, so it doesn't interfere with my enjoyment of the amp. It still sounds great to me. I just thought there might be a way to eliminate it completely, but now I don't think so. I'd appreciate any suggestions anyone might have, though.
