blackdragon87
I wanna buy an WA2 please pm me if for sale. 115 VAC
Read some thread about it and it seems to be „snake oil“I use these “Burn-in tools” when I power up my tubes.
Well at least its only a few dollars. I don't think you'd need anything plugged in for tubes to burn in as long as the current is going and its a' glowin'.Read some thread about it and it seems to be „snake oil“
Not according to Woo(at least on a WA33)
It really depends on amp Design.That makes sense. I don't think WA33 is an OTL right? Then it should maintain some sort of load (e.g. headphone plugged in).
The manual only states "Allow approximately 5 minutes of warm-up."I try to let my WA-22 warm up about 1/2 hour if I have the time. Otherwise, I fire it up and listen and notice the changes as it warms up. No right or wrong answer just depends on your time frame and your patience
To clarify.Read some thread about it and it seems to be „snake oil“
I use a few tubes that make “tinkling” noises for at least 20 minutes until they are fully warmed.The manual only states "Allow approximately 5 minutes of warm-up."
This is precisely why I use the xDuoo “burn-in tool” when powering up either WA6-SE or WA22.Out of curiosity(and boredom) I checked the owner's manuals I could access. The following explicitly state to plug in a headphone before powering up: WA2, WA3, WA5 LE, WA6, WA6-SE, WA22, WA33. The manual for the WA7 Fireflies does not recommend plugging in a headphone or I missed it. I could not find an online manual for the WA23 or WA234.
It says it is 3.5mm. How do you use it with a woo amp?I often turn my amps on at least an hour before I intend to listen. I use these “Burn-in tools” when I power up my tubes.
It provides a 16ohm load, and if something went bad upon warm-up, my expensive headphones would be spared any possible damage.
3.5mm to 6.35mm adapter.It says it is 3.5mm. How do you use it with a woo amp?
I've never plugged a headphone in my WA2 while it warms up and never had a problem.Out of curiosity(and boredom) I checked the owner's manuals I could access. The following explicitly state to plug in a headphone before powering up: WA2, WA3, WA5 LE, WA6, WA6-SE, WA22, WA33. The manual for the WA7 Fireflies does not recommend plugging in a headphone or I missed it. I could not find an online manual for the WA23 or WA234.
