Woo Audio Amp Owner Unite
Feb 24, 2017 at 8:43 PM Post #39,271 of 42,298
  No luck. Tubes not heating up. Maybe the CV1285 is not equivalent tube.
Everything I see seems to indicate they are.
Bummer.
i use those tubes with adapters  as drivers in my WA22 .Not sure but looks like a screw up in compatibilty chart as far as i recall you only use adapters with the ECC31 tubes the other ones are plug &play
Feb 24, 2017 at 8:50 PM Post #39,272 of 42,298
This is from the ECC31 thread
Feb 24, 2017 at 8:53 PM Post #39,273 of 42,298
Feb 24, 2017 at 9:23 PM Post #39,274 of 42,298
Thanks for the link.Without the adapter the CV1285 did not heat up . With the adapter, I didn't touch the tube but also did not see it glow. Maybe I just got dead tubes, but they look pretty new. And the seller seems pretty legit; old_guy_radiola on eBay. Has the finest collection of awesome  and unusual tubes I've ever seen.
http://www.ebay.com/sch/old_guy_radiola/m.html?_nkw=&_armrs=1&_ipg=&_from=
Feb 24, 2017 at 10:04 PM Post #39,276 of 42,298
Why does Woo Audio's site  say no adapters for any eccxx ?
 take a look --> https://docs.google.com/spreadsheets/d/1DdsZyTx3CJv9_cG9kVdCGZap-AldiTsvuY4Ms1K_p3k/pub?hl=en&output=html
Feb 25, 2017 at 8:00 AM Post #39,279 of 42,298
i tried my ecc31 on my wa22 without adapter....but it didn't have any sound...lucky the tubes not spoil..... confirm ecc31 need adapter on wa22....
. Yes they do. Picture of adapters above
Feb 25, 2017 at 10:24 AM Post #39,280 of 42,298
Maybe I got a defective pair of adapters.
They are inexpensive so worth another try.
But takes a while from China.
Feb 25, 2017 at 1:00 PM Post #39,281 of 42,298
I have those adapters, good socket quality. tell seller your adapters are not working if your sure its the adapters and he should replace them usually they do .here's where i got them price is for one adapter
  http://www.ebay.com/itm/1pc-Gold-plated-ECC31-6N7G-TO-6SN7-CV181-B65-ECC32-ECC33-tube-converter-adapter-/201134198992?hash=item2ed48850d0:g:LNYAAOSwPcVVvs1s
Feb 25, 2017 at 3:16 PM Post #39,282 of 42,298
Thanks. I had already bookmarked that particular adapter. Figure I will pick them up. I had ordered some slightly cheaper ones. Wonder the likelihood the ones I got were duds. Would be awesome if I could get those tubes working
Feb 25, 2017 at 3:21 PM Post #39,283 of 42,298
Is there one tube that works maybe you could swap sides just to see if the tube is to blame or the adapters
Nobodys perfect i guess wouldnt be the first he makes a mistake
Feb 25, 2017 at 9:53 PM Post #39,284 of 42,298
yes they do it's just weird that on their own site Woo doesn't state that one needs adapters for the eccxx's too bad I guess..
