abvolt
Why an adapter for the Tung Sol 6SN7?
That's a socket saver not an adapter..
I guess I didn't know there was such a thing.
Too bad. I have the same Tung Sol 6SN7 in my WA5 and the base came loose on one of them. Still works fine but I have to be careful to grasp just the base when inserting or removing. The pins were pretty corroded and the Woo socket is pretty tight. So I polished the pins. But I am very reluctant to change out those tubes now. Which is not a giant problem because I don't know of a better 6SN7 for the Woo anyway.
Do you?
I use super glue with my loose base tubes just put a little all around where glass meets base so far they stay glued
Check out the mullard ECC31's they are not too high priced you can get a great early 1950's pair for around 260. much finer sounding then any 6sn7. When I tried them & the 32's 35's I was sold never going back
Check out the mullard ECC31's they are not too high priced you can get a great early 1950's pair for around 260. much finer sounding then any 6sn7. When I tried them & the 32's 35's I was sold never going back..
So I snagged a pair off of eBay for $244!
I love Mullards. Have the CV4003s in my PrimaLuna.
Can you recommend a source for an adapter?
Thanks for the tip.
Anybody want a used Tung Sol with a loose base?
Yes I am lol. My problem is that the noise (which is tolerable though) keeps existing, without source.
Just got my Wa7's in and up and running
