Badas
- Jul 9, 2014
That's a good result.
That is a sweet setup. I might not be able to scrape up somethng as good.
I think I will use 596, TSRP 6C8G and 6BL7. It should be okay.
Actually, it might not be. I've found I get a loud hum when I try to use a 596 with TS 6F8G's, I assume because of all the unshielded wires.
I have used my wa5 with the 6f8g and 596 and don't get any hum what so ever.
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
Yes, you are right. Those wires need to have good shielding to be quiet. Gelnn's adapters work great for them.
I've got Glenn's adapters for the 6F8G's with the left/right orientation for the wires so they're out to each side and the Woo adapter for the 596 but none of the adapters have shielded wires so the tubes can't be used at the same time without hum. It's not a problem, just a combination that doesn't work in the WA22. My normal setup is the WE 422a rectifier with the TS 6F8G's and TS 5998's. That's a combination that works like a champ.
Interesting, so within the space of a few days, the V281 makes your tube amp useless and irrelevant, and suddenly! it might be good? You come across as very polar. Not really interested in finding the realism in anything, just touting the extremes. I guess that makes your life exciting
