Silent One
What silence said... then nothing.
- Aug 9, 2010
yes, i have been eying his wa4 and mini tori
1. WA4
2.
3.
I forgot about the mini torii!!! My pref for the WA4 is locked! Which of the remaining three amps would I want to demo thru the D7000's: LF; Beta22; Mini Torii for the final two slots?
1. WA4
2.
3.
2) Liquid fire
3) Beta 22
you're welcome
1. WA4
2.
3.
LF, I don't think Mini Torii is ideal for the D7k unless you feel they are somehow too analytical or dry.Though the Torii is one of those amps you maybe want to try as you might not see another for awhile, if ever.
Woo audio has the two 6SN7s in series running on 12 volts so if one burns out the outher will not light. You may only have
one bad tube.
Worth investigating, Have tried searching for the Woo circuit diagrams online but understandably they probably keep the designs close to their chests.
San Raal, You way you describe it sounds dramatic the arcing you got, The amp just shrugged the incident off? "Pfttt, is that all you GOT?!")
Question for you champs. How do you folks manage your valve stock? Aside from rolling for flavour, do you do much rotation or do you pretty much run them in to the dirt then swap? I'm flogging the crap out some Woo supplied tubes for the warranty period, but I was thinking of swapping the stock tubes back and grinding them down to nothing (or until intolerable, but I don't know what that sounds like)
Hi Davidio,
I honestly don't know why my TSRP died when they did. I wouldn't want to speculate without concrete evidence. Please dont take that as an indication your Mullards will fail before their time!
It was an expensive month in Feb, I went on a 6SN7 spending spree and ended up with quite a few NOS, some JAN Ken Rad, Valvo and JAN NU black glass and the new prod Shugang Treasure. Settled on the Shugang CV181 over NOS for my Woo5 (Its electrically equiv to a 6SN7 not a true ECC32/CV181 like your purchasing) I'm sure that you'll be very happy with your ECC32 purchase, its an investment as the value of those tubes will only go up. One would also hope that the premium you pay at an online tube vendor over a private sale is peace of mind if they are DOA.
I had a pair of the Mullard ECC32 pass through 4/5 years ago for around $200 and couldnt use them as the heaters drew too much current for the 7812 regulator in my old amps supply. Wish I had kept hold of them too!
San Raal,
Thanks for the words of encouragement. Brendan at Tube World assured me that the old ECC32s are very rugged, and that I should expect them to last several years under average use.
He also informed me that the cryo'ed tubes had no real claim to a longer life span, but that the process of freezing them actually improved the SQ and made the bass tighter and the mids more revealing. Although, it seems to me that the reinforced molecular structure of the metal should make a tube stronger and thus longer lasting. I wouldn't make any promises if I was selling cryo'ed tubes, either, because no two tubes are created equal. One might last 8,000 hours and another 5,000. We'll see!
What made you settle on the Shuggie Treasures over NOS tubes? I've heard conflicting reports about treasures...that they start out sounding like they are going to be stellar and then they settle into a more average SQ. Others say they sound better than any of the respected NOS 6SN7s. Also heard they settle into a darker, less revealing sound. But I see they've updated the CV181-z to a newer model, with a "t" or something at the end, instead of "z." What is your interpretation of their SQ with the Woo gear?
It has 4 amp heaters, not safe to use in a Woo amp.
