Zalithian
- Jan 3, 2009
I do like my MKII's but I like the SM3v2 better. Hmmm.. can I keep both?
What exactly are the Jays names? Website I can purchase? Thanks
Do the Comply T-400 tips fit these fine?
Only if you use the "rubber core" mod, where you cut the inner core of some other tips that fit the GR07, place them on it's nozzle and then place the T-400's over those, as their bore is too large to use directly...
It is supple, but its a type of non slip rubber that is very comfy around your ear. It does its job just fine.Maybe discussed earlier but this is my question: I loved the earguides of Westone um3x. Stiff and the headphone never moves out of your ear.
This thing looks supple and feels (based upon photos) as if it could fall off your ear anytime to turn your head.
a. How is the fit of this gr07 mk2?
b. If bad, know anything to improve it?
Thanks
Omg yes! The gr07 BE are my go to's for EDM, nothing beats them for pure impact from top to bottom while still maintaining control, just fantastic.If you love dubstep like your avatar says then you should look into the gr07 bass edition which are an upgrade version of the mk2 with better extended bass response.
The BE drops deeper than MKII and has a slight boost in the sub region for that elusive rumble we loveSorry folks, haven't really been paying much attention to the GR07 Bass Edition ...... I have the MKII and MKI (2nd version) .... I like the improved highs on the MKII but overall like the MKI better because to me, it sounds like the bass has been compromoised on the MKII.
So ...... would you say the GR07 Bass Edition is an MKII with improved or emphasized bass (which sounds exactly like what I'm looking for), or is it more complicated than that?
