I think most of your concern as a vegan is in the leather pads. Senn or Beyer headphones for example mostly use velour or pleather so I think that should be fine.
Many think the AH-D 7000s by Denon have leather ear-pads. They are not real leather. Some wood was used though. So I guess a living thing gave it's life for em.
I never though of them as cheap, but you may have a point there. Come to think of it, I have never had a set of leather pads? I am not sure what they would be like. I think I did try some R-10s with em at a meet once. I figure the whole thing with pad material comes to mind after much use, if your not vegan then your just concentrating on the sound. Most pleather does seem to peel off after a couple of years of heavy use. They also have a material called Ultra-leather which is a urethane bonded to Lycra which I have heard never peels off. No one I know uses it though outside of the motor home industry? Cost may be a factor as it is more than leather. If someone obtained a line of aftermarket ear-pads with Ultra-leather I am sure they would be a great seller due to the comfort and durability factors.
Leather can wear out the same as pleather depending on the quality of the leather and how well it has been treated, but I think for the most part it is about that luxurious leather feel. That's something I would expect from a $500+ headphone that doesn't use velour. The ESW9's use leather earpads and headband and are also nicely priced at around $250.
I never understood why the Audio Technica W1000x is marketed as a luxurious headphone with wood earcups and a beautiful finish, yet still have pleather pads.
