dwinnert
- Nov 5, 2011
As long as they don't use leather pads etc. you should be fine with that specific headphone depending how strict you are. Just know that even if the pair you buy is vegan, does not mean that the money the company made off you is not used to purchase animal products for other products in their line. Also headphones with wood might be treated with beeswax or some other animal product. Chinese also might use an animal based glue in the assembly. Steric Acid is used in rubber and plastic production. Animal fats are used in plastic molds as a release agent.
I have friends who are strict vegan and won't even buy products from companies that manufacture any products with animal sources. It can be difficult.
Anyhow, good luck.
Anyhow, good luck.
