'Genres' would work for your local files (assuming that you have edited the metadata to reflect your particular 'Genres' wording), but I am not sure about streaming (I don't stream).
USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
Hi all,
I didn't find any solution to my problem in this thread so sorry if it has already been solved.
I noticed that first 1 or 2 seconds of tracks are missed in UAPP, and noticed that this happens only in some cases :
- when starting the app,
- when the track is on pause
- when switching to a track that has different (higher as well as lower) bitrate or sample rate. When switching to a track that has same bitrate and sample rate, the change is smooth and nothing's missing.
I face this problem on my Cayin N7 and curious enough, it also seems to happen on other apps (Neutron, Poweramp, Cayin / Hiby).
I played around with the settings of UAPP but couldn't find any solution yet.
Only solution for now is after switching track, restart the same song to have the first notes.
Has anyone encountered this problem yet ? Thank you
Simon Patten
Actually I noticed that earlier. I haven't had time to investigate it, I assumed it was a bug in the latest version and will get fixed soon.
I could be wrong but it seems to me like an old problemActually I noticed that earlier. I haven't had time to investigate it, I assumed it was a bug in the latest version and will get fixed soon.
Brain Damage
When you have opened UAPP, try going into:Hi all,
Has anyone encountered this problem yet ? Thank you![]()
settings/USB audio tweaks/Buffer size
Change this to a higher setting. Should work
Thank you for your suggestion, unfortunately it doesn't work for me, I tried 600ms and 32768 frames.When you have opened UAPP, try going into:
Change this to a higher setting. Should work![]()
I send an email to the support, they seem quiet responsive. I'll let you know if I have some solution to share.
Simon Patten
Sorry, mis-posted.
- May 27, 2011
What are the UAPP settings I need to know to reduce battery drain if I’m just playing local FLAC
Brain Damage
As far as I am aware there aren't any settings as such. The fact you'll be able to play local files without the need for WiFi/mobile data to be switched on will reduce battery drain.What are the UAPP settings I need to know to reduce battery drain if I’m just playing local FLAC
m-i-c-k-e-y
Try investing on a TASK Manager that will regularly "Kill" apps that are needed during startup and in regular intervals to save battery power and allocate more processing to running apps.
WitzyZed
No idea how heavily animations hit the CPU/Battery department nowadays, but disabling those in UAPP's UI options could be worthwhile.What are the UAPP settings I need to know to reduce battery drain if I’m just playing local FLAC
Only other options that come to mind are: forcing black color background, disabling any forced upsampling, and making sure 'keep screen on' stays disabled.
Can't use the (paid) UAPP on another Google account?
- May 27, 2011
Subscriptions are linked by account, not deviceCan't use the (paid) UAPP on another Google account?
milkdudd
- Jan 3, 2017
Most of my listing is Qobuz streamed over Wi-Fi to a non-activated Android smartphone (in airplane mode) with all apps turned off except the bare minimum to make it work. I connect it to my DDC with a USB on the go cable. My player is USB Audio Player Pro. I see there are settings for network buffer size, network chunk size and another buffer size in a different category of settings. I have no idea how to optimize these settings. It's working fine but that doesn't mean it couldn't be better. If anyone out there is using UAPP and has a good understanding of what these settings do and how to set them, I'd appreciate it if they would share them with me. Thanks
Simon Patten
As a wise man once said, "If it ain't broke, don't fix it."
The defaults should be fine for most circumstances.
Total: 20 (members: 0, guests: 20)
