Oct 24, 2022 at 3:55 AM Post #5,611 of 6,408
Hello guys, I have a newbie question. Is there a way to play YouTube via UAPP?
Oct 24, 2022 at 6:02 AM Post #5,612 of 6,408
Oct 30, 2022 at 3:09 PM Post #5,613 of 6,408
Thanks for your response. This is Informative. Just one more question
Is it possible to include option to play songs from cloud storage like onedrive or google drive? Similar to DoubleTwist Cloud Player
I think it's really time in 2022 to implement it since most newer phone have no expendable storage, otherwise UAPP ia soon to be irrelevant without the space for enough audio files.
Oct 31, 2022 at 12:46 AM Post #5,614 of 6,408
Not if you have a upnp server running but thats a valid point
Oct 31, 2022 at 2:02 PM Post #5,615 of 6,408
I use my setup mostly at work. I have my own webdav server which I could connect to if it was managing it as a library with caching and such. I would pay for more space on my Google Drive as well if that was an option. For now I'm using my old cellphone that still have a sd card slot, but when that one gives up the ghost that will be it, UAPP won't have a purpose anymore for me.
Oct 31, 2022 at 2:23 PM Post #5,616 of 6,408
Every single time I reboot my Nvidia Shield I get the message from UAPP: allow usb audio player pro to access X-SPDIF 2? This app has not been granted record permission but could capture audio through this USB device.
This is very annoying. How do I prevent it from appearing?
Two suggestions:
1. It might be that the app's permission was never granted. Open the app settings, check permissions, and ensure that all its permissions are granted. If any are not, grant them.
2. If might be that Google Play Protect removed the app permissions. It does this automatically to apps that aren't used often. If this happens, use step (1).
Nov 7, 2022 at 6:01 AM Post #5,618 of 6,408
Hi I'm using UAPP for awhile now (Hiby R5) but don't have any EQ presets . can I get a file with presets ?
I can't use murphit since my IEM (KZS) not supported
Thanks
Have you looked at Autoeq? It has presets for many IEMs. You'll probably have to enter PEQ values manually in UAPP.
https://github.com/jaakkopasanen/AutoEq
Nov 7, 2022 at 7:27 AM Post #5,619 of 6,408
Yes I did but I guess I can't download it to my hiby R5 as a package but rather have to enter the values manually
When entering manually there's a value called PK which I'm not sure what is the correct correspondence in the tooneboosters menu ( LS I guess means low shelf ? )PK stands for Peaking filter but the dropdown on the TB menu doesn't have peaking filter listed as an option
Thanks
Nov 7, 2022 at 7:38 AM Post #5,620 of 6,408
Thanks
I can't remember for toneboosters, but it's sometimes called "analog bell" or "digital bell" instead of peaking.
Nov 7, 2022 at 8:34 AM Post #5,621 of 6,408
I've signed up for free trial with Tidal, and threw £10 at this app inc the MQA approval .
I'm disappointed. I use the Qudelix and Sundara and Amazon music so it's easy to flick between Tidal/UAPP and Amazon. I can't hear any difference, not a bad thing, MQA v Ultra HD both sound superb .
The Amazon app is glitchy but still better than the awful UAPP Tidal interface, trying to produce playlists and negotiate the app is a pain.
Sound is superb admittedly
Nov 7, 2022 at 1:00 PM Post #5,622 of 6,408
Thanks
Thanks much for your help!
Anyone here knows how to import EQ Presets into UAPP ? the autoeq on github has it all in .txt format which the app doesn't recognize as importable file
Nov 12, 2022 at 2:55 PM Post #5,623 of 6,408
Hello guys
Sorry if it has been answered (I could not find it in this thread) but is it possible to normalize the volume of each track somewhere in UAPP. I tried with replay gain but it's not working. I use bit perfect
It's really annoying when changing tracks and they sound different in volume 🙄
Nov 13, 2022 at 4:01 AM Post #5,624 of 6,408
Indeed, UAPP looks very good on Qobuz but not on Tidal.
Nov 16, 2022 at 5:19 AM Post #5,625 of 6,408
Hello, can anyone tell me the correct filename format for UAPP to show the song details correctly?
On my Android phone, I have a few albums named like this:
Artist – Album – 01.Song name
For those, I am getting Unknown artist during the song playback.
I have one album named like this:
01.Artist - Song name
For this, I am getting the Artist name correctly.
Besides that, how can I make UAPP show the Album art all the time? Because when I put my phone to sleep and open it again, a generic image is shown and not the album picture. I have one album picture saved inside each album folder.
Thank you
