jlemaster1957
Ok tried that using R8 and no go- I get the message ‘failed to find HiRes DAC.’Thanks- I will try that and report back. I learn something every day here!
My usual settings have Android Audio to ‘Device native sample rate’ and ‘internal hires audio’ ‘Bit perfect’= ‘when possible’. Upsampling settings are irrelevant to the issue. If I change the above settings I get the problem noted in para 1 above. Settings as is will allow play everything but when I try to select EQ I am told ‘Bit perfect mode!’ (! not mine).
