weexisttocease
Any further details for the iBasso DX240? Tidal or Qobuz streaming still not working. No MQA as well.
Sorry if I bring up this "old" question, but I would like to solve the same problem......
I have tried Neutron (demo version), same behavior as UAPP. However, Neutron is able to add a network folder (using Samba) to its library, scanning it as if it was a local library, and it has an option to split multi-disc albums in two separate entries. This solves the problem. But I'd rather use UAPP that has a much more pleasant UI. Is there any workaround for UAPP ? Can UAPP handle network folders in a similar was as Neutron ? Looks like UAPP can access network folders but just as a browser, you cannot add folders to the library.
What kind of upnp\ dlna software do you use on the NAS?Sorry if I bring up this "old" question, but I would like to solve the same problem...
My large library is on NAS shared with samba, but UAPP allows me to browse files only in folder mode ... while Neutron (demo) scans the files and allows me to select them by genre or artist etc as if they were local files.
Is there any possibility of doing it with UAPP too? I find it better with the interface and the sound but I really need to easily navigate all my files.
Or do you have a suggestion for a bitperfect application that can do this bypassing Android stack on my Hiby R6.2020? I have already tried HibyMusic, Onkio HiFi, PowerAmp ...
Thanks for your help!
I'm actually not using upnp/DLNA but only direct samba sharing... since my NAS does not work properly in upnp/DLNA (I can only see a tenth of the files...)What kind of upnp\ dlna software do you use on the NAS?
I know that samba is a more basic sharing but I was impressed with Neutron's network-scan and thought UAPP did it the same way.
Not much info out there for Tonebooster. How do the filter names translate to what's used in Peace or APO?It's a paid add-on inside the UAPP app. I think it costs a few bucks, $1.99 when I bought it. It adds PEQ to UAPP.
That's exactly what I was looking for. Thank you so much!I'm not familiar with Peace or APO. Maybe this will help:
https://www.head-fi.org/threads/usb...ort-for-android.704065/page-331#post-16460368
Android version may be too old.Is there a reason I am unable to install Wavelet, UAPP, poweramp, etc to my Astell and Kern SR25? Wavelet just says 'App not installed' when I hit install, UAPP and poweramp prompt for the install and then say "There was a problem parsing the package". I'm really annoyed right now because the native EQ for this DAP is not very customizable, and just trying to find an EQ app that I can customize. I'm using XAPK Installer to install these. So far only Tidal and Spotify have successfully installed.
None of those programs are on A&Ks "whitelist" and therefore can't be installed on any A&K player.Android version may be too old.
FWIW I have an X5III and I can login to Tidal. My UAPP version is 6.0.3.2.Tidal login broken again on FiiO X7. Anyone else?
