LightBlue77
And how to do this? Have the beta that is...
You can opt in from the app page on the Play Store.And how to do this? Have the beta that is...
Yes, it works for all devices with your Google account.When someone has a few different Android devices, on the same Google Account - do you know if opt-ing in on one device, will change the UAPP on all the devices?
Shanling M6 Pro 21 (Firmware: V1.1) with the USB Audio Player Pro or UAPP (V5.9.9.9), Listen to Tidal (with a Hifi subscription).
Song Title: MOZART Violin Concerto in D major KV 218, I. Allegro (MQA Remix 2016). That has an "Original Sample Rate" of 352.8kHz.
Question:
1)
With the following settings:
Internal Audio Driver > HiRes Direct Driver
Internal HiRes Audio > Bit Perfect Mode >On
Internal HiRes Audio > Upsample > Off
MQA with Blue light appears. 88.2 kHz shows on both "Direct" and the status bar (upper right).
I understand that MQA was decoded (first unfold) by UAPP, not by Hardware from DAC ESS ES9068AS. On the other hand, I got downsampling from 352.8 to 88.2 kHz.
Why Hardware decoding/rendered is not working? But I got downsampling instead?
2)
Internal HiRes Audio > Bit Perfect Mode >Off
The "Original Sample Rate" of 352.8kHz changes to "Sample rate" 44.1 kHz
No light appears next to MQA. 44.1 kHz shows on the "Direct". But 705.6 kHz shows on the status bar (upper right).
According to the information from https://www.extreamsd.com/index.php/mqa , "When a DAC is detected that implements an MQA decoder (for example, the Meridian Explorer 2 or the DAC inside certain LG models), the MQA decoder inside USB Audio Player PRO is deactivated and MQA decoding is performed by the hardware. No green or blue led will be displayed in the app in this situation."
I understand that No light appears as the Hardware decoder/rendered is working.
2.1) Why 705.6 kHz doesn't appear in "Direct", and does the "Original Sample Rate" of 352.8kHz change to "Sample rate" 44.1 kHz? Note that "Original Sample Rate" doesn't show in the "Meta data".
2.2) In this situation, why is M6 Pro 21 upsampling the song beyond the "Original Sample Rate" of 352.8kHz? (refer to the photo of the "Meta data" above)
2.3) I understand that it should be a maximum of 352.8kHz, am I right?
3) Does M6 Pro 21 already support by UAPP?
Thank you
Is there an actual link to click to get the beta on the Play Store? I know in the past you had to e-mail Davy at extreamsd.com and request it.You can opt in from the app page on the Play Store.
Buy the add-in.Whats the best way to add autoeq to UAPP?
Thanks, was looking at it from the PC!As others have said, you can join the beta from the Play Store page for UAPP on your android device. Sometimes Davy has test builds for specific issues that he sends via email for troubleshooting, but that's a different scenario.
Ive got all of them. But how can access to autoeq? Wavelet for example do it automaticallyBuy the add-in.
Un UAPP you have an inapp purchase named Morphit. It's the most close to autoeq you will find in UAPP.Ive got all of them. But how can access to autoeq? Wavelet for example do it automatically
