I am expecting this tooWhen I’m testing 6.0 with DX300 I’m getting unfold only with addon. My R8 opposite doing full 16x unfold with no blue or green light - exactly how it is described in manual. I’m expecting DX300 also to be recognized as MQA decoder..
USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
behemothkat
Speaking frankly, having before DX220 and DX220MAX i never got MQA unfold natively on both. Now the same experience with DX300 and DX300MAX.I am expecting this too
The truth is that it is a shame, because UAPP is my application of choice and I really prefer to use it instead of Mango.
Hi, when I go to "my tracks" of Tidal it doesn't give me all the songs anymore.
Maybe UAPP Beta has limitations?
behemothkat
For me works like a charm.. Okay, correction: a bit slower than usual.Hi, when I go to "my tracks" of Tidal it doesn't give me all the songs anymore.
rlw6534
The R8 is a full MQA decoder and doesn't actually need the MQA add-on. Not sure on the DX300 (decoder or renderer?), maybe when Davy adds full support it will get sorted.
behemothkat
It is decoder, otherwise it won’t be able to go beyond first unfold in Mango and Tidal apk.The R8 is a full MQA decoder and doesn't actually need the MQA add-on. Not sure on the DX300 (decoder or renderer?), maybe when Davy adds full support it will get sorted.
rlw6534
All MQA decoders and renderers go beyond the 1st unfold by design. The difference is that a renderer needs the 1st unfold done in software (2x) and a decoder can decode the original stream without software assistance. Non-MQA devices can still have the 1st software unfold (2x), but that's it.It is decoder, otherwise it won’t be able to go beyond first unfold in Mango and Tidal apk.
MQA can be confusing.
wizzman121
I just installed the beta on my DX160. It sure looks like the interface has prioritized the tall skinny screen dimensions of modern smartphones over the more traditional aspect ratio found on DAPs. The first pic is the 5.9.9.9 and the second pic is the beta. Kind of disappointing to see the artwork get so tiny
5.9.9.9
6 beta
5.9.9.9
6 beta
behemothkat
At least DX300 was advertised as decoder.The R8 is a full MQA decoder and doesn't actually need the MQA add-on. Not sure on the DX300 (decoder or renderer?), maybe when Davy adds full support it will get sorted.
rlw6534
Cool. I did a quick Google search before and it wasn't clear in the specs. I have an Hiby New R6 which is also a full decoder. Maybe Davy can get the DX300 sorted soon. There must be something odd about it (causing it take so long to support).
behemothkat
He did mention few pages back he finally got DX300, so, can test it now..Cool. I did a quick Google search before and it wasn't clear in the specs. I have an Hiby New R6 which is also a full decoder. Maybe Davy can get the DX300 sorted soon. There must be something odd about it (causing it take so long to support).
Soundizer
- Dec 29, 2015
Is there a link to this UAPP player as i can see multiple Apps like this on Google Store.
i am looking to side load onto Nvidia Shield TV Pro.
Thank you
Thank you
wizzman121
Right hereIs there a link to this UAPP player as i can see multiple Apps like this on Google Store.
Thank you
Soundizer
- Dec 29, 2015
Thank you.
it doesn’t work for TV Streaming Services does it - Netflix, Prime, etc?
Total: 13 (members: 4, guests: 9)
