I had hoped it would be fixed by today’s Pixel security update - can anyone test?It's a problem with the pixel that stops it letting dacs control the audio. No solution at present.
USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
Hamlap
Thanks.It's a problem with the pixel that stops it letting dacs control the audio. No solution at present.
That sucks...
Hamlap
Just updated. No differentI had hoped it would be fixed by today’s Pixel security update - can anyone test?
Hi guys,
I'm using UAPP with Samsung Galaxy Note 4 with an RME-ADI 2 DAC, is there a way I can control / stream to UAPP from my desktop PC?
I've heard about media servers but this is all new to me?
Just turn on UAPP's built-in UPnP Renderer (in the menu) and you should be able to stream to it from any UPnP control point, including your PC. When the UPnP renderer is turned on, UAPP also shares tracks in its library as a DLNA server. If you choose to play any of those tracks, UAPP will detect that it is a local file instead of receiving it over the network. Pretty clever!
simon740
Hello,
can I ask why my LG v40 doesn’t play native DSD? I have Uapp on my V40 and then connected to adi-2 dac fs.
DoP is fine , but no native DSD.
Regards,
Simon
Regards,
Simon
I believe it was Android 10 update which killed native DSD.
simon740
My V40 is on Android 9I believe it was Android 10 update which killed native DSD.
I see. In that case I don't know. I have V30 with Oreo and Pie (two phones) and both of them play native DSD.
m-i-c-k-e-y
Read the manual of your DAC... Think its DoP only on Linux/Android.
On Windows both DoP and Native.
Hello,
Regards,
Simon
alexdemaet
Sacd iso from a nas Usb audio player pro +Neutron player
I have a couple of sacd Iso files stored on a nas. Because of storage limitations, I have saved them on a nas. Unfortunately, I can not see the sacd iso when I am browning on the nas via the Neutron music player and the Neutron music player. Is it possible to fix this so I can play them straight from the nas? Browsing and playing the iso from an internal memory card works fine. But the internal memory has limitations
alexdemaet
I just got a response from the creator of Neutron music player !Sacd iso from a nas Usb audio player pro +Neutron player
It depends on the NAS or the settings of the NAS. You won't find ISO's
using UPnP/DLNA normally since the NAS needs to chop it into tracks.
Using SMB/WebDAV/FTP etc, it should be possible to play ISO's.
I have not figured out yet how to set up a Synology Diskstation with DSM 7.0 so it will split the tracks of a sacd iso. I also have a Qnap TS469 pro. I have asked support from both companies
MikeyFresh
You should split the tracks yourself into .dsf files, you can then alter the metadata if you chose and add album art as well.I have not figured out yet how to set up a Synology Diskstation with DSM 7.0 so it will split the tracks of a sacd iso.
alexdemaet
Yes. I also have seperate dsf fles but it should work with iso files as well.
Reminds me as to where I was a couple of years ago with my old Readynas Duo v2. Still a really good NAS for my music. Exactly where you are (were). Google MinimServer and try: - https://www.sonore.us/iso2dsd.html for splitting ISO's to DSF/DFF etc
cirodts
- Jan 27, 2016
This eq is very interesting "toneboosters" but the peak filter is missing and I cannot set it with oratorio 1990, how can I do?
instead of the peak filter which filter can I set on toneboosters?
