ratdog
- Jun 2, 2004
Is there an ETA?Not yet
Already answered by the developer - when Amazon provides the required access to their service.Is there an ETA?
It's been pointed out in this thread very recently that UAPP does not use Android audioflinger but rather other dedicated audio APIs provided by manufacturers where available... And the bugged result of trying to use UAPP HiRes on our players which do not provide such an API certainly attests to that (although as I pointed out, in our case simply enabling variable sample rate output on standard Android driver allows the same results on PCM audio)Hello! I`d like to know your opinion...
Here:
http://4pda.ru/forum/index.php?showtopic=194117&view=findpost&p=90166641
the developer of another player(Poweramp) claims that you are deceiving everyone, and supposedly the tracks from your player are down-sampled. In confirmation, he even brings some sort of screen from the terminal, looking at which, I would have to believe that downsampling is present.
I repeat, I would really like to know the opinion of the UAPP developers on this matter. And most importantly, I would like someone more knowledgeable than me to be able to enter into a polemic if necessary, because personally it seems to me that just what Mr. MaxMP claims - this is a real lie...
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Here:
Hi, Davy,
I am a long year UAPP fan (with my old OnePlus 3T and tried it also with OP 6 of my son). In the last Year I didn't even need my the LH GeekOut Infinity v2 USB, because after tweaking the internal Hires parameters the SQ with the builtin DAC is sufficiently good without an extrernal DAC.
Just some observations and one "request":
1.
In contrast to the recommendation to set the HIRes driver audio format to auto, I coud get markedly better sound with fixed bit depth of 32 - at the cost of battery consumption, which I am willing to pay for it. Just with this is now on par with the HiBy SQ (and also battery drain).
This is interesting, because the builtin Snapdragon WCD9xxx DAC officially only supports 24 bit (but obviously doesn't reject 32 bit input).
Is there an explanation for it? (My best guess: internally takes places a conversion to 32 bit which is of lower quality than the algorithms of UAPP). This observation could be important, when this is valid for all of the WCD9xxx of the many Snapdragon SOCs.
2.
I also found upsampling to a multiple of the input is definitely beneficial for SQ. With my RME Babyface on PC it is even displayed by the performance indicators, that such an upsampling takes place internally within the DAC if it is fed with a lower sampling rate input.
3.
Another previous observation with external DACs: by attaching an external power supply (by attaching the DAC to a good quality powered HUB) I got a night and day improvement, over a range of DACs I have tried. (This applied also to the PC USB - e.g. my RME BF became my best DAC, better than the DSD capable LH GOV2 with HQPlayer).
4.
To MQA:
a.) I don't see why the limitiation to BitPerfect with MQA playback is necessary, it makes the excellent parametric equalizer unusable. Only in connection with an MQA-capable HW seems this reasonable, but after having to convert it to PCM, a processing should be possible?
b.) I cannot quite understand, how MQA (from Tidal) can sound so dramatically better than normal CD when playing it through the MQA AddOn (which I purchased). I would expect that the biggest improvement is in the BitDepth of 24 bit, and that is in the unfolded MQA with 24 bit isn't it ?
If not so, shouldn't be rather 16 bit displayed while playing back without the AddOn? (With normal PCM files I couldn't make any big difference with higher sample rates, but very much with bitdepth over 16 bit.)
And to my Request: I am using "Other Radio Stations" a lot as relatively good quality Classical and Jazz sources (the few broadcating in flac appear to vanish, but 320kb is often just enjoyable while travelling). Could You consider please to display the Meta Date of the just playing music, VLC player can do this also on Android?
Tell that to MQA... :sigh:Thank You Davy, very honest indeed, and also informative.
You are certainly more in the position to be heard Your opinion regarding MQA restrictions regarding DSP Usage, so my considerations:
The primary need for using an EQ is by the huge and probably growing community of aging audiophiles is a massive one: to compensate for high frequency hearing loss and as such is comparable to using spectacles. Nobody would deny using eyeglasses to visitors of an art gallery, just for sake of unaltered visual perception - rather to the contrary, an authentic perception could only be restored by using such correction tools. I personally have a 1,5 kHz wide 8-10 dB bump around 4 kHz at least for the last 30 Years, and now above 60 I have to apply a high shelf additionally to compensate for age-dependent loss above 10 kHz.
In addition to this to compensate for some gear specifics should also be considered as legitimate.
BR. Attila
BR. Attila
Hi, Davy,
3.
Thanks for explaining this, Davy. I assume you mean resolving the sorting issues when track queue in the playlist did not correspond to actual track order in the folder? If so, you did a pretty good job! That was actually the first issue I met and contacted you regarding that a while ago. It's really great you managed to fix it.
Anyway, if you find an alternative way to parse files and avoid long delays many people including me would be very grateful. Those, who listen through folders, usually use folders containing albums or compilations and in some cases they can grow quite large in terms of number of files inside, taking into account that modern DAPs can easily handle memory cards up to 512Gb.
I might have improved speed while retaining correct sorting order. Please send me an email at info AT extreamsd.com if you want to test a beta.
I would just like to add that my cheap Chinese tablet and phone are working just fine with UAPP with default settings. If @Davy Wentzler would like to know which devices, I'm happy to PM them for you to add to your list of compatible android devices.
@Davy Wentzler
Greetings Davy.
Long time user of your app and loving it so far (keep it up!!). I'm using it with my Asus Zenfone 6 and a Dragonfly Red (for now). I would like to ask you guys something: I use 2 google accounts on my phone. I've bought the app in one of them (the old one) but would like to transfer the license to my newer one. Is this possible?
