USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
Oct 30, 2019 at 3:59 AM Post #3,181 of 6,188
@Davy Wentzler
Greetings Davy.
Long time user of your app and loving it so far (keep it up!!). I'm using it with my Asus Zenfone 6 and a Dragonfly Red (for now). I would like to ask you guys something: I use 2 google accounts on my phone. I've bought the app in one of them (the old one) but would like to transfer the license to my newer one. Is this possible?
Just switch the accounts once the license is checked after 24 hrs. Solution?
Oct 30, 2019 at 10:32 AM Post #3,182 of 6,188
Hi guys
It's looks like I'm the only one here who have huge collection of music in APE files ?
Oct 30, 2019 at 11:13 AM Post #3,183 of 6,188
What shine's me away from Monkey Audio's .ape audio files are:
1. limited online download support
2. limited hardware/software support
3. cpu intesive/slow decoding
4. no streaming
Though it doesn't mean its sonically inferior, no. On the contrary it makes perfect, bit-for-bit copies of your music. But gone are the days of making CD/SACD or even LP rips. I now purchase my music online or thru streams. And seldom I encounter .ape files.
My preference formats are: flac, dsf/dff or SACD ISO, DXD/Wav.
Nov 1, 2019 at 10:52 AM Post #3,184 of 6,188
I'm in trouble with my Honor 9 Lite.
I'm using UAPP and two different DACs, the Chord Mojo and A&K AK10.
Either sound good but it's the "clicks & pops" festival.
I tried all the tweaks included in UAPP without results.
I' ve also swapped different usb cables, no luck.
Any help?
Nov 1, 2019 at 10:58 AM Post #3,185 of 6,188
Any help?
Unless proven otherwise, it's the same problem as Huawei/Honor devices have been having since years. 6 clicks per minute due to the buffer feedback size from the DAC to the host is wrong.
Nov 1, 2019 at 5:33 PM Post #3,189 of 6,188
Do you know if UAPP is likely to work correctly on the Sony A100 & ZX500 range of android DAP's ?
I know only just coming out but wondered of you had tested your software on them.
Nov 4, 2019 at 12:06 PM Post #3,190 of 6,188
I need some help!
I installed the UAPP app on my Samsung S7 and when playing a song after 60 seconds volume increases about 20-25 %
I reinstalled the app but it happens again.
I have the Player pro app and also the Poweramp app but no problem with them
What do You think?
Nov 4, 2019 at 12:17 PM Post #3,191 of 6,188
I need some help!
What do You think?
You activated MorphIt or the parametric EQ without having purchased it. It stops processing after 1 minute.
Nov 4, 2019 at 12:55 PM Post #3,192 of 6,188
Ah...thanx very much!!!
Problem gone and now i understand. I paid extra only for EQ.
I dont know what Parametric EQ does and the Morpit. I dont really hear a difference.
Preamp i miss a little but i guess i dont need it. I have a Fiio Montblanc amp
Played with the eq and it sounds very good. Better than Poweramp and Player pro
Nov 6, 2019 at 1:45 PM Post #3,194 of 6,188
Comparing a smartphone with Uapp vs a dap like Cowon plenue D2 or Fiio M11 when it comes to soundquality.
Is there a big difference in soundquality?
I have the Samsung S7 and use the Uapp and it sounds very good to my ears.
A long time ago i had the Cowon M2 and sound was good. A little bit better than an older samsung i had.
Nov 9, 2019 at 9:53 PM Post #3,195 of 6,188
@Davy, for UAPP with Tidal, can you consider implementing a sort by "Date added" in the "View all" screen of "New tracks" please?
Presently, one can only sort by "Track name" and "Artist".
A list of new tracks sorted by date added would be very convenient if one is looking for the latest tracks to check them out or just to listen from the latest to the oldest additions.
Thanks.
