The Takstar, Technical Pro, Gemini Greathon, CyberX, Qpad Thread
post-11477799
Post #3,046 of 4,668
DJScope
post-11477893
Post #3,047 of 4,668
alphaproject
Not to mention the Hyper X has a mic from what I see at amazon. They are $70 there but I paid $43 for the Gemini version.
post-11480001
Post #3,049 of 4,668
DJScope
Are the Cloud earpads better? If so, in what way?
Better than the original ones. Original ones are shallow and quite hard. This is why mostly everyone hear who own the Takstars use the HM5 ear pads.
post-11485757
Post #3,050 of 4,668
wanderjahr
Ahhh, ok. Thanks. I just bought the HM5 earpads based on some recommendations in this thread, I didn't realize the Cloud II already had decent pads. I guess they'll just be better pads now. Thanks again!
post-11488903
Post #3,052 of 4,668
Roderick
Finland
Finland
post-11489100
Post #3,054 of 4,668
alphaproject
Yea...wow the black velour look NICCCEEEE.
post-11489853
Post #3,055 of 4,668
aaDee
Just realised Cowon C2+ Topping NX1 combo was completely wrong for Takstar Pro80 + HM5 velour pads. Mid bass was completely absent and highs were little too sharp.
Used Cowon C2 + Fiio E6 and wow....this combination is just perfect. Bass is back, highs are not harsh. Bass bleeds into mids a little but its just when you compare with other combination. Otherwise it helps in making mids more fuller. I had to sacrifice on soundstage a bit but the difference too small.
post-11490242
Post #3,056 of 4,668
BigGearHunter
I'll be honest, people are still raving about the HM5 velour pads... I didn't like them. $25 for a bit of extra comfort, modified sound (for the worse in my view) decreased isolation and a magnet for fur and lint. I went back to the stock ones and I'm much more happy with them.
post-11490248
Post #3,057 of 4,668
spurxiii
The pleather HM5 is much better
Reactions: DJScope
post-11490490
Post #3,058 of 4,668
Roderick
Finland
Finland
I  use velour on hi2050 and pleather on pro80. Bass got bit boomy when I had pleather hm5 pads on hi2050 and pro80 sound a bit thin with velours. People who design headphones usually know what they are doing so most of the time you don't get better sound using pleather pads on a headphone that is tuned to be used with velours or the other way around. Both pads are excellent when pad material is chosen accordingly, often increasing the sound quality even on more expensive headphones. For example I've used velour hm5 pads on hd600 and pleather ones on w1000x.
post-11490568
Post #3,059 of 4,668
alphaproject
Yea, I've been heaing that now. Using the velour changes the sound too much from what I'm hearing. Go stock or use the pleather ones I'm hearing.
post-11490950
Post #3,060 of 4,668
DJScope
I like the original pleather ones, not the memory foam one. It's waaay more plush.
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
