BenF
- Jan 22, 2013
KA11 will drive any headphone with normal (>100dB) sensitivity, as long as it doesn't have high impedance (over 64Ohm).wow thanks man....
which i was suspicious too ... but can u recommend me a USB dac which is affordable ? I am looking at this :
https://www.fiio.com/newsinfo/893399.html
If you insist on planar headphones like Hifiman HE5XX or Takstar HF580, you'll need more power.
The cheapest option is FIIO KA13 (on sale for 68$: https://www.aliexpress.com/item/1005006045454559.html
You'll need to purchase a balanced 4.4mm cable for your headphone though, as the 3.5mm output isn't powerful enough.
Another option is FIIO K5 Pro ESS on a huge sale for 90$ (normally ~145$): https://www.aliexpress.com/item/1005003682930042.html
It can drive 1.5w into 32Ohm, and doesn't require balanced connection.
I would recommend going for Takstar Pro 82 v2 and FIIO BTR3K - this combo will give you a much better sound that any entry-level planar like HF580 or HE5xx at much lower cost. It will also sound just as good on the go using Bluetooth.
https://www.aliexpress.com/item/32808454492.html
https://www.aliexpress.com/item/1005006673970584.html
You can buy BTR3K anywhere, but it's important to buy Pro 82 v2 at the TakstarAudio store, as other stores may send the wrong version.
