castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
I disagree. bigshot's punchlines and straight to the point attitude result in him making many claims about things being inaudible/irrelevant for humans. many of his claims are an overreach compared to the available data or can be disproved by the available data.The BIG difference is that what bigshot claims is almost always in agreement with the science (so it is NOT "sans-proof") and on those relatively rare occasions when it isn't in agreement with the science then I or someone else pick him up on it, request some reliable evidence and refute his claim if he doesn't provide it. You get exactly the same courtesy, however, you are "picked up on it" far more often because you contradict the science far more often!
no matter the topic, the fundamental disagreement will be on what to do with the exceptions. <=== !!!!!!!!!!!!!?
often the topic itself is going to be about the exceptions or the absolute limits where they may or may not occur. the typical stand around here is that exceptions are only exceptions and don't change the statistical answer significantly leaning toward a clear result. and this would be fine if the many statements about inaudible stuff were clearly presented as statistical statements under clear conditions. but stuff like "jitter is inaudible", and "all DACs sound the same", are not it! at the very least, when presented that way, those statements are not in agreement with science. because science will see the exception as evidence disproving the statement. or at the very least, demonstrating that the model is incomplete and fails to describe all the present conditions. either way, science would demand a modification of the statement. which is sort of what Keith is aiming for, even if he sometimes has a roundabout/I want to believe, way of presenting the need to modify the statement.
while bigshot typically will argue that the exception is not something that should happen, or that it would happen with gears he would call defective(most likely, so would I). and while we all understand the rhetoric here, and we all sort of agree(including Keith) in practice that the stuff said to be inaudible are probably not going to be and are very unlikely to ever matter to a random audio enjoying his music, from a strict scientific position, discarding those exceptions, that's just bigshot manipulating the data so that his conclusion can hold.
I've had this discussion almost as many times as Keith, and we're all sick of it, but something has to give. you guys either make a statement along with the specific criteria for it to be true(perfectly fine conditional truth). or you stop making those big global claims and start talking in term of statistical confidence that something will happen. then we're all on the side of science.
@bigshot. IMO, you should make a detailed post, stating how when you discuss relevant or significance, you mean at an audible level for a non mutant human listening casually to fairly typical music at safe listening level, etc. and list for DACs, amps, cables, what you wouldn't accept as a valid sample for any test regarding your statements(and maybe why). do something like this once, add what you come up with as you think about it, and add this in your signature with a warning that the link lists the conditions for your statements. so you don't have to keep explaining what you meant when you didn't specify those and someone didn't read your mind or knew you well enough.
I usually suggest that to the troubling subjectivists, telling people to add in their sig that all their claims are based on subjective experience, or just to have a little "IMO" as a warning for anybody who actually cares about reality. but it might save you and others a lot of time and avoid many more conflicts if you had something like that in your sig, serving as default parameters when you can't be bothered to list them along with your statements(and maybe if you do a good job, it might become the go to reference for more people).
