I'm still waiting to see a list of the "countless tests" that you and BigShot are privy to... but the rest of us are not.
(And please make sure they meet his requirements for "a real test and not just anecdotal evidence".)
I do apologize... that was a low shot.
I actually believe that you may have conducted some tests to confirm this yourself....
Or that you even have enough experience to make a generalization that is usually true....
It's only BigShot who would insist that, since they weren't published, or peer reviewed, your tests are meaningless and we should ignore them.
However, your assertion is false..... about the metals.
Nowhere does the term "two blocks of metal" specify "common metals" nor "metals that occur in nature".
I simply asserted that, under some circumstances, when you bang two blocks of metal together, you get a fission explosion.
Oddly, yet again, in one sentence you accuse me of being absurd, but in the next sentence you concede that I'm technically correct....
(And I don't at all disagree with you that the circumstances required for that result would be relatively uncommon.)
However, there have in fact been several recent cases, one or two with tragic consequences, where someone incorrectly assumed that the chunk of metal they found WASN'T highly radioactive.
One was a fellow who made a keychain out of a piece of metal he found in a junkyard... it looked like a fish weight but turned out to be the Cobalt 60 slug from an X-Ray machine...
(He ended up dead a few days later - thanks to his assumption that "it must be an ordinary piece of metal" - and the resulting lethal case of radiation poisoning...... )
Also, humorously (or not), I read once that, when looking through some old file folders in the basement of the pentagon, a brick of plutonium was found, stuffed between two documents in folders.
(It had come from the desk of one of the scientists at the Manhattan Project... and gone unnoticed when his office was packed up after the project was closed.)
(Plutonium itself, in small quantities, is not especially radioactive, and can be handled more or less safely.... )
However, you are
MOSTLY correct, and assumptions like that
usually don't kill anyone.
I'm also pretty sure that Einstein was one of the guys who was in favor of "banging blocks of metal together to see what would happen"....
(He surely would have been offended if you'd suggested that it was an absurd idea.)
And the US government spent quite a lot of money and effort accumulating enough plutonium and enriched uranium to try it out....
(And, yes, as it turns out, in most cases, unless you bang them together quite violently, and hold them together for a short period of time, all you'll likely get is a loud noise and a fatal case of radiation poisoning.)
Real science is the part where you do experiments to test the theory...
Suggesting that we needn't consider the condition "because most people will never see it" is really closer to some sort of "consumer reporting"...
(Which is an extremely useful thing... but not exactly science.)
Also, from the title of this area of the forum, I was hoping this forum might be a place to discuss science....
As in....
- Gee, I think I observed something....
- Here are some theories about what it might be....
- Let's find out....
Instead, as far as I can see, every time anyone even suggests something like that....
The result is that they're told that: "We shouldn't waste our time because we all know they must be imagining it."
(Perhaps we should change the name from "TESTING audiophile claims and myths" to "DISPROVING audiophile claims and myths" or even "DEBUNKING audiophile claims and myths"... )
Although, honestly, I would find that rather boring...
Incidentally, just to put BigShot's paranoia to rest, if you check out the jitter specs on Emotiva's DACs and other products (that's the company I work for).....
You'll see that we don't even bother to publish jitter specs....
(So I guess that they really aren't "yet another marketing ploy used by all evil audio companies to trick unsuspecting consumers into buying stuff" after all...)
1. No that is NOT true, it's just yet another misrepresentation (sigh!). The BIG difference is that what bigshot claims is almost always in agreement with the science (so it is NOT "sans-proof") and on those relatively rare occasions when it isn't in agreement with the science then I or someone else pick him up on it, request some reliable evidence and refute his claim if he doesn't provide it. You get exactly the same courtesy, however, you are "picked up on it" far more often because you contradict the science far more often!
2. That is indeed a serious issue, because it's just yet another typical audiophile marketing ploy! "Science" is already defined, you do NOT get to redefine it to suit your (marketing?) agenda. And worse still, you definitely do NOT get to redefine it in such a way that's pretty much the exact opposite of what science actually means! What you often argue is not just hypothetical situations that can't/don't exist but hypothetical situations which themselves contradict science. For example, can we state that: If a pig had wings, plus the skeleton, musculature and other attributes necessary to generate flight, then we would have a flying pig? No, we can't! If such a hypothetical creature actually existed, it wouldn't be classified by science as a pig, it would be some other class/genus/family of animal. Our statement would NOT be "pure science", it wouldn't be any sort of science, it would be "pure" nonsense! ...
2a. This isn't a nuclear physics forum and I'm certainly no expert on the subject but if we assume that I'm correct, then I don't need to make-up my own nonsense example, you've done it for me! Firstly of course, our two pieces of metal would NEVER "happen to be plutonium". Except in trace amounts, plutonium doesn't exist in nature, it has to be manufactured and when it is, it's probably about the most controlled metal on the planet. So, we've got a hypothetical that's nonsense to start with but there's even more! Even if it were possible, just banging together two pieces of plutonium wouldn't cause a nuclear explosion. Nuclear bombs are high precision devices that use a shaped explosive to "implode" the plutonium so the released neutrons sustain a chain reaction rather than just escaping into the atmosphere, they are not just simple devices that bangs two pieces of plutonium together. So in fact, you would indeed still just get a loud noise (plus probably a fatal dose of radiation). Your example is an assertion which isn't even true within the confines of your own (effectively impossible) hypothetical situation! This is all so ridiculous, nonsensical, false and anti-science that I struggle to find a term that does it full justice. The best I can come up with is "UTTER NONSENSE" but you've come up with a different term: "PURE SCIENCE", which of course leaves me struggling for another term, one which does full justice to just how much you are attempting to pervert the word "science"!!
3. "The answer is ..." - A false assertion, what a surprise! A 30 sec file containing nothing but a 20Hz sine wave is a test signal recording, NOT a music recording. So in fact you've failed to answer the question, another surprise!
4. Oh good, another circular argument based on fallacy/misrepresentation and a nonsense hypothetical.
4a. Here's our nonsense hypothetical. There are no commercial music recordings that have a -50dB white noise floor, unless you're truncating to 9 bits with TDPF dither, know many of those do you? Nor any with nothing but but a -70dB jitter sideband (and our hypothetical -50dB white noise), nor any DACs which produce a -70dB jitter sidebands!!
4b. OK, let's run with your nonsense hypothetical.
4c. Sure, so? What you appear to be arguing is that *YOU* are maybe ignorant of what the measurements mean. In which case that's obviously an issue of your ignorance, not an issue with the science or objective measurements. Or, are you saying that if we limit your measurement (to 999-1001Hz) but don't state it's been limited, for example, effectively some marketing lie/omission?
5. Very true, I've tested this myself, numerous times. BUT it entirely depends on the frequency of the pure tone and the precise nature of the noise floor. In other words, there are a particular set of conditions required in order for a pure tone to be audible below the noise floor. Therefore the question becomes; when are those conditions met? The answer, in the case of DAC jitter artefacts and listening to commercial music recordings (at a reasonable level) is never!
5a. We do NOT assume that jitter sidebands will be masked by the fundamental and harmonic frequencies of the music content, we assume they will either be masked by the noise floor (which of course comprises all frequencies) or simply not reproduced in the first place. And of course we don't only rely on this assumption, there have been countless controlled listening tests which verify it.
5b. Which is irrelevant (effectively a misrepresentation!) because we're talking about audibility and we do not hear true peak level, we hear loudness (or lack of it) which isn't directly related true peak level.
6. Nowhere do I recall Einstein saying "Everything should me made as ridiculous as possible and then base some false assertion on it" but if he did, wouldn't that have to be your absolute favourite?
G
