TheSonicTruth
- Dec 19, 2014
Sorry, I used the wrong word. I meant sound quality, not sound fidelity. I fixed it.
I've always thought the two at least overlapped.
80kHz is so far beyond "enough" I can't help you if you don't "believe" it. We've been down this road before, though, so I don't expect you to give an inch on your unsubstantiated claims.
He's right. It doesn't matter what he is listening to. You're talking about frequencies you can't hear as if they are important. And I don't need to consult your doctor to know you can't hear it... unless you aren't human?
[1] And, of course, since test gear always measures "numbers", it cannot reach conclusions about what is or is not audible.
[1a] (So no test set I am aware of will EVER tell you that something "is or is not audible".)
[2] Many people seem to have an unfortunate tendency to treat values presented as a single number as if there's nothing else involved...
[2a] This assumption is totally untrue and inaccurate - and can lead to many incorrect conclusions...
[1] In this thread, there is a marked tendency to oversimplify; world consists of only RBCD, loudspeakers and headphones have uniform or benign impedance characteristics, etc. [1a] In such a limited kindergarten playground, ...
[1b] "all cables/amplifiers/whatevers measure and sound the same" may even - within reason - hold true. And it , to a large extent, does.
[2] Step into the real world - and this house of cards gets blown away in a heartbeat. It may well be fringe examples - but they are real, as well as you can read this. And can be measured and can be heard.
[2a] It only depends how much one is willing to investigate.
[3] I am perfectly OK with the conclusion " performance of this calibre is not significant nor required in MY case/application"
[3a] - but not when trying to limit any further progress by saying that RBCD is all it will ever be required for music reproduction - not to go into lossy files.
[4] If anyone doubts this position;
[4a] ask, before or after another live concert involving acoustic drums, to be allowed to "play" ( or play for real, if you can ) a few strokes/hits on the snare, tom, kick and cymbals ... - and honestly answer yourself if ANY of the RBCD recordings played back in your home sounds even remotely as realistic.
They can, sometimes, in certain regards but there's no direct correlation.I've always thought the two at least overlapped.
Ultimately, human ears. What are you using?OK - first a question for you. What source(s) are you listening to ?
Question for you - can you hear noise ?
It only depends how much one is willing to investigate. And, above all - LISTEN. I am perfectly OK
with the conclusion " performance of this calibre is not significant nor required in MY case/application" -
If anyone doubts this position; ask, before or after another live concert involving acoustic drums, to be
That's because stuff is done in mixing and in post to the recordings of those drums!
AS: Do you not realize that digital - CD specifically and digital audio as a whole - does nothing to the captured sound? PEOPLE do - with effects processing, at every stage of the album-making process!
For crying out loud listen to some Chesky or GRP label stuff, and not Billboard Hot 100 releases, which have had some much CRAP done to them that they bear next to no resemblence to the sound of the initial studio sessions.
Things done in post on most commercially released, particularly
digitally recorded or digitally remastered recordings ...
less talked about, the better.
"digitally recorded" or "digitally remastered" have nothing to do with it.
It's how much or how little post-processing, and what types, are done that matters - not whether that processing is done in the digital or analog realm.
The most important things are composition, venue used, performance, and session techniques - what gets captured in the first place, and also choices made at the mix and mastering stages of the project. Not what format(analog or digital) the processing and/or delivery takes place in.
I honestly don’t think he can help it.
But no Chesky release I have ever heard did not have the directness of a
well done binaural - or not nearly to the extent of which dispensing with ALL unecessary
mumbo jumbo in the signal path can provide.
Things done in post on most commercially released, particularly digitally
recorded or digitally remastered recordings ... less talked about, the better.
Billboard is something to which I have , at least consciously , never listened to - even
for a second.
1. True, test gear is designed to measure actual properties of digital audio data, an analogue electric current or sound pressure waves, not how/if we may or may not hear/perceive them.
1a. That's nonsense of course! Objective measurements of audio properties themselves (by definition) obviously will not tell you that, you need to compare the objective measurements with what is reproducible in the first place and if it is reproducible (under reasonable listening conditions), then we can compare the measurements with hearing thresholds, using common sense/logic (IE. A brain)!
2. That depends on what the numbers are. Ultimately, digital audio is just a single set of numbers (representing amplitude over time). However, both measuring equipment and human hearing/perception can derive further information from this single set of numbers. Your argument (particularly in regard to THD) appears to be based on a common audiophile fallacy, actually several fallacies. For example, the difference between measurements of actual audio properties and published equipment performance specifications (for marketing purposes). Often we can treat a single measurement as if there's nothing else involved, it depends on the value of that single measurement, which brings us back to 1a.
2a. That's because "many people" don't seem to know what hearing thresholds are, and/or are not able to apply "common sense/logic". Although to be fair, much of the audiophile industry obfuscates or lies about hearing thresholds and makes the application of common sense/logic nearly impossible for "many people". Your argument appears to be circular!
1. Who in this thread has ever stated that the world only consists of CD and that speakers/HPs all have uniform impedance?
1a. A "limited kindergarten playground" that doesn't exist, that you've just falsely invented to push your false agenda (yet again).
1b. The actual "playground" we're in, is that of human hearing and yes, "within reason" it holds entirely true.
2. This is the self contradiction at the heart of nearly all your posts here. The "real world" you refer to is not "within reason", it is beyond reason and often so far beyond reason that it's completely ridiculous. So while it is the "real world" in the sense that it can be measured, it's a completely nonsense, fantasy world as far as what "can be heard" is concerned. Sure, we can measure 1mHz and far beyond, even into the Terra-Hertz range, but it's utter nonsense to state that it "can be heard"!! In other words, "this house of cards gets blown away in a heartbeat" ONLY if you completely ignore any sense of reason!
2a. It does indeed depend on how much one investigates and I would suggest you start by investigating the well researched/established science, especially considering what sub-forum you're in!!
3. Clearly that's not true, just another self-contradiction! "MY (our) case/application" is that of human hearing but you are NOT "perfectly OK" with that. Your "case/application" appears to be the hearing of some other creature, presumably some fantasy/alien creature because not even animals on this planet known for their high-freq hearing (such as dogs, certain bats and dolphins) can hear 1mHz as far as I'm aware!
3a. I'm perfectly fine with limiting progress to what is humanly possible and don't see the need for a limit applicable to some hypothetical alien species ... but that's just me! Maybe if I get abducted by aliens (with ultrasonic hearing) I'll change my mind?
4. Such as - any sane person?
4a. Huh? Why would I want a CD to sound like a real acoustic drumkit when the engineers/musicians have spent days deliberately making the drumkit sound nothing like an acoustic drumkit? Are you talking about an alien drumkit? Do aliens even play drumkits?
G
