Incorrect, but see below.
No, not without knowing what changes were made in production.
Lets get specific rather than using massive and irrelevant generalities. What parameters in a capacitor are no longer available? And "the sound quality" doesn't count! Be specific!
That statement indicates a full lack of understanding of how a DC servo works. I'm not going to explain it, as that's a huge tangent, but for a start: you don't apply it to an input! No need, and no point. So, no chance at all of "blowing up" a cart. Works just fine, and is a very nifty way to eliminate huge caps in the audio path.
It doesn't matter. The entire scenario of needing to reduce gain because of gain/bandwidth product, then having to hit it so hard that you needed a higher output preamp (like what, +/- 50V???) is irrelevant and stupid.
The response above was fully expected, but disappointing. It's typical audiophile: "You haven't hear it, so you don't know. You probably couldn't hear it anyway because you are 1)deaf 2)an idiot 3)your system is far to unsophisticated. Thanks for following suit with expectations, but none of that supports even a single one of your arguments.
There it is again. This time it's the "20-20k minded".
I do. It's exactly what we get now. You've fallen into the "circle of confusion" once again. So you think everything needs to be capable of some RF frequency like 100mHz, but you want everything in the chain to do that. Most mics don't, can't and won't, and are chosen for other far more audible and important parameters. The mics that do are useful for very limited applications. We could digitize up to 100mHz, but we're not going to because there's no evidence it makes any difference above 20kHz or slightly more. No analog recorder will record above 20kHz reliably and consistently, and none at all above 25kHz that don't have some other fatal issues. No speakers can deliver anything to your ears above 25kHz at all, even if stated response is 40kHz, the ultrasonic beam width and air absorption blows it away. The whole argument collapses if you look at any individual segment of the chain, but you want the WHOLE CHAIN to play up to 100mHz!
RIAA EQ doesn't dictate a feedback network, but ok...
There's no such thing as zero-tolerance parts. Even the ones with values printed on them have a tolerance, usually 1%, but possibly lower. But you clearly don't understand either the RIAA curve or what tolerances are necessary.
Well, that may have been true in 1977, but not true today. Easily measured, with non-exotic equipment. But again, you're in the circle of confusion! So, we have a preamp with precise RIAA match to the mDB. Great. But how does it perform with a cartridge on it? Oops. You might measure it if you had a test records recorded with no EQ and a perfectly flat lathe. But then we get into the real problem, the record RIAA eq may not be that good. And since the entire produced response is based on what was heard in a studio with monitors that are not flat to 2mdB, likely not to 1dB, we have another random error built into the system. Then we hit your speakers in your room, and response errors become HUGE because I'm 100% certain you make no attempt to equalize them in the room (an audiophile atrocity). So why on earth would we need or benefit from 2mdB response accuracy anywhere? We cannot possibly achieve it at all, not even close.
Wow. You couldn't BE more wrong! US FM (and most other countries) runs from 88-108mHz! AM radio is between 535-1605kHz! Analog TV channels 2-6 are between 55-83mHz! CB radio is centered around 27mHz (AM and SSB), HAM radio frequencies are all over, from 135 meters (135kHz), up to 50mHz in 13 separate frequency bands!
But...I also think you're misquoting the specs. You've confused mHz with kHz. From memory I recall that the AGI, while pretty wide band, didn't really perform much above 100kHz. That's Kiloherts, not Megahertz. So you're right, it rolls off below most high power RF. But it's far from the only preamp that would do that. For example, the Apt-Holman preamp was -3dB at 150kHz with the ultrasonic filter switched out. I recall the Marantz 7T being good to 100kHz too. So, no big deal there. However, RF proofing is quite another matter.
Wrong again, on several points. In fact, the only thing right in the above paragraph is that a MM cart won't work well into 500pf! But they don't have to. Simply placing a 500pf cap on the front end won't RF proof it at all. Several preamps, including one by Kenwood, and the notable Apt-Holman, solve the RF problem by not using a bipolar transistor at the front end. A bipolar junction acts as a diode detector/demodulator at RF frequencies, becoming the root cause. Eliminate that junction, you don't have a detector.
Again...the actual electronics involved is very different here. What you describe (actually not in the schematics available on-line which show a bare-foot uA749 opamp as the front end!) is just a low pass RF filter. The function of which would be necessary for any preamp operating in a high RFI field.
Oh, yes. Been done. The Apt-Holman was designed within 1 mile of a high power broadcast transmitter! And I have actual hands-on experience with phono preamps and all sorts of other audio gear at both a 20kW FM transmitter site and a 50kW AM transmitter site. There are plenty of other preamps that will work out there, but none (AGI included!) will work without very special attention to installation and grounding.
I thought that thing was special too...in 1977. But time moved on, it's not special today at all, nor has it been for 30 years.
Well, in "Picking capacitors" slew reate may have been mentioned ( don't care to check it, 3 metres away in the library ) - but VERY briefly. Since it was also a thinly disguised advertisement for what later became known as Wonder Cap, there was no warning saying film caps can have VERY large differences in slew rate. From just a few (single digit ) volts per microsecond to aprox 600 ( at least back at the article publishing, but is not much different today ).
Regarding differences made in production; IF that first amp heard at friend's contained "vintage, definitely in limited supply, not to be available again- ever" caps of superiour quality, and the one bought later with whatever best available from the current production, but inferiour to vintage caps - you WOULD mind. That's why manufacturers avoid such situations at all costs - and build with whatever is currentlyproduced and likely to remain available in at least few years ahead. That means an old(er) design may well be, ultimately, superiour sounding for this very reason.
With the miniaturization and advent of SMT /SMD, unfortunately MOST of the best capacitors once used in trough hole variety have been dropped. Simply because they can not withstand the temperatures of the SMD/SMT soldering process - further made worse with the introduction of the lead-free solder ( which requires yet even higher temperature ). Only the most THERMICALLY robust varieties of film capacitors remain available in SMD form - and those are NOT the equal in quality of say polystyrene as dialectric material. And, yes, capacitors DO have different sound quality - even IF the electrical measurements, down to the last DA and whatever electrical parameter ( triboelectrics, anyone ? NO mention in "Picking Capacitors" , THE fatal flaw of teflon caps ... ) are identical. Now try to figure this one out ...
I do know how a DC servo works. And did post its use at the input as the ultimate no-no. Sooo - if your preamp input is directly coupled to a phono cartridge AND there is a catastrophic failure of preamp ( one of the rails blown, latching to whatever remains, blown input semiconductor, etc, etc ) - would you still insist on direct coupling ( best for sonics, no doubt about that ) - or would you insure yourself from blowing up an expensive cart by using ( best quality you can get ) cap ?
No, that scenario is not stupid. Because it does SOUND better than having to insert another gain stage between the preamp input and - call it that way - driver of the "power amp". And yes, although not +-50 V rails preamp, it was close : +- 45V rails. But, I agree it is not the normal way of doing things and incompatible with most other equipment.
You are , of course, free to think this way. But I ( or anybody else ) can not convince to the contrary anybody - online. Only on the real demo floor, with real equipment of high enough quality.
Yes - because a SINGLE "20-20K" minded component in the entire audio chain, from the microphone to the whatever used as the end transducer back to sound, is enough to throw the spanner into soundstage works. Now - go to any studio - and count 'em ...
No, I do not want the whole chain to play up to 100MHz - because I am realist. It is unlikely to happen - ever, but certainly not in my lifetime. However, ANY stage that can be made large bandwidth will contribute to more accurate recording and reproduction. And I have NEVER said that < 20 Hz and > 20 kHz is more important than 20 - 20K, or even more important 100 to 10K band. Only if this core band is OK, would I try to stretch to either of the extremes. As the easiest way to start doing it is in amplifiers, I started with them.
There are microphones made specially for music that go to 100 kHz. There is any number of headphones that go - at least - to 40 kHz; and an inch or so of air can not filter the driver output before it reaches the ear in any significant way. Furthermore, that the attenuation of high frequencies in air is so severe I find hard to believe; my recordings ( never use anything that might be categorized as close miking ) do show sound clerly related to music - all the way to 55 or so kHz ( where the quantization noise of the ADC starts to keep rising ), depending on the instrument(s).
As I type this, I am lidstening to and looking at Voxengo Span display of 192/34 transfer of yesteday's DSD128 recording ( clarinet as lead/solo, violoncello, viola, 3 violins, acoustic bass, accordeon, piano and percussion ) - from the rehearsal, where there was less noise than during the concert ( damn lights, audience was generally VERY quiet ...) I remember a light ( reflector, something like that ) has been switched on during the 12 minute take of rehearsal - and, presto, a constant peak of 19.0 kHz at - 66dB crept in ... and I dread converting DSD to PCM and looking at what has been switched on during the second part of the concert - EVERY damn light in sight dimmed - yuck...!
However, I did not know clarinet has so much output above 20 K - at very least to 40 kHz, during the solo clarinet passage. One learns every day...
And the beat box used by the percussionist goes to 50 kHz on this recording - some at least 5 metres from the mike; clarinet between 2-3 metres, depending on player's position on the stage.
RIAA can be implemented in many circuit configurations - and I have only described the one as used in AGI 511.
I agree there is no such thing as zero tolerance parts - but the best approximation, as most probably used for the AGI, is some Hewlet Packard RLC meter. OK, " measured to be exactly 123456 ohms, with the tolerance from the absolute correct value as specified by XY measurning instrument" - would that satisfy you ? And, yes, the values of resistors in RIAA circuit are printed down to the last ohm - like 23732 ohms and NOT 24 K 1% ( or any other value/tolerance) . Caps are not - because, for those less familiar with film caps, even picking them up with anything more than feather touch can change their value - let alone re-printing them. For this reason, no desoldering and measuring the super precise ( aka close to zero tolerance ) parts from AGI 511 ( or anything else built with even approaching this quality of parts ) is NOT recommended.
I am well aware of the cartridge/preamp interferace problems. And so was/is Mr. Spiegel - 511 works exactly as well as any other correctly designed preamp when it comes to interfacing with real world MM cartridge and its RL characteristics .
No, I did NOT confuse kHz with MHz - correct as written. However, you are right, AGI 511 overall HF limit is set by its line stage, which is approx 100 kHz.
You are correct in stating that whatever has been used in a studio has been way off the accuracy of the RIAA precision of AGI. Then again, it is not AGI's fault to try to strive for the precision - and studio folks being satisfied with sloppiness.
I do not know which schematics of 511 you did find online. It is NOT a single op-amp - in addition, there are ( bipolar?- would have to check it ) transistors used as feed-forward - that's where 100 MHz+ capability of the circuit is coming from, not from the slow IC op-amp.
I agree installation and grounding are paramount in any phono ptreamp. But none I am aware of can reject this much RF garbage as 511. Enough is to see the open box - plenty images online.
I disagree - there still is nothing comparable up to today. The only gripe I have with 511 is the use of that ribbon cable for all the connections - because that adds approx 80 pF of capacitance per each input, unfortunataly sometimes this is too much for some of the best MM phono cartridges - after the cabling from TT to preamp has already contributed at least 100 pF - if not more.
