SONY IER-Z1R
Feb 27, 2020 at 8:27 AM Post #6,736 of 15,276
Feb 27, 2020 at 5:32 PM Post #6,738 of 15,276
He's just insulting you. :wink:
I get that part. I was asking how he figures that putting lube on a connector that sometimes has gold plating specifically to improve contact conductivity will have no impact.
Feb 28, 2020 at 2:46 AM Post #6,739 of 15,276
Welp!! I got my z1r’s today. I swear I said let late last year I would never spin over a $500 for a pair of IEM’s coming from rhe Z5’s MY GOD!!!! Do they get better with burn in? I just can’t wait!!!
Feb 28, 2020 at 4:35 AM Post #6,740 of 15,276
Congrats!
If you're not blown away after 2 h of listening, then don't bother with burning in, as it's not gonna change that.
What I would be nervous about is fit and that's where you should really focus your attention: finding a good, deep, comfortable fit.
Almost 1 year later I'm still completelly satisfied with the IER-Z1R.
Feb 29, 2020 at 6:04 AM Post #6,743 of 15,276
Feb 29, 2020 at 10:53 AM Post #6,744 of 15,276
Hey guys, I’ve just upgraded my Shure SE846 to the IER-Z1R and am amazed at how good they sound. I was looking for a pair of over ear headphones and somehow ended up with these instead, lol. I’m running them with a Chord Hugo 2 as my semi-portable music solution and they seem to pair together very well. I didn’t get on too well with the supplied ear tips so am currently using Comply foam tips which allow me to get them inserted deeply in my ears but over time they work themselves loose and I have to gently push them back in every 30 - 60 minutes. Anyone else had this issue?
Feb 29, 2020 at 11:07 AM Post #6,745 of 15,276
If you are useing tips without wax guard you can try to turn them round with the widest part to the front, then they tend to stay in better. Personally I use the Final E tips
Feb 29, 2020 at 11:49 AM Post #6,746 of 15,276
I have same poblem with the stock tips of IER-M7, the go out every 30 mins
Mar 1, 2020 at 4:00 AM Post #6,747 of 15,276
I had all these problems with insecure and painful insertion in ear. All of this was ended when I switched to Fiio cable rather than Sony stock. The over ear preform on Sony cable plus the long plug body at the MMCX caused the iem to be pulled out of my ear. See my earlier posts.
Mar 1, 2020 at 12:20 PM Post #6,749 of 15,276
Think I might be sending these babies back. They sound awesome but definitely not the sound I thought it was gonna be for $1600. Guess I’ll just get another pair of Z5’s
Thanks for that info.
Mar 1, 2020 at 12:24 PM Post #6,750 of 15,276
What kind of sound were you expecting ?
