REVIEW: Head-direct.com HiFiMan EF2 tube Hybrid Amp with USB DAC
Jul 28, 2009 at 9:59 PM Post #121 of 1,326
hello I am new to all this stuff and I am trying to setup a system to buy
so far people have told me to do this
-senns hd600 headphones
-iBasso d10 cobra as the usb amp
- the ef2 as the tube amp
and connect the ibasso to the ef2...
or should i just buy the hybrid?
Is this good for a stationary setup? it will be staying on my desk connected to my computer.
or should I look for a differnt amp/dac?
Also can I hook up external speakers to all this in the future? because it is a lot of money to just spend on a headphone setup...I would feel better if I knew i could setup a stereo system with it..
Jul 28, 2009 at 10:16 PM Post #122 of 1,326
it'll work as both a dac and amp.. if you want to use the d10 as a DAC and the ef2 as an amp, that sounds like it'd work great
it's a great budget desktop setup and yes u can hook up active/powered speakers but i'm not so sure about bookshelf speakers, probably not enough power.
Jul 28, 2009 at 10:54 PM Post #125 of 1,326
I may be getting ahead of myself, but I have another question in regards to my upgrade path after the EF2..
I will be using the DAC as a source maybe 80% of the time, and the Fuze w/ Line Out as a source maybe 20% of the time.
If I wanted to improve my setup in the future... which option would be the most beneficial?
a. add a dedicated DAC and use the EF2 as an amp
b. use the EF2 as a DAC/preamp and add a dedicated amp
c. upgrade the tubes
d. a & c, or a & b
Thank you
Jul 29, 2009 at 12:53 AM Post #128 of 1,326
The EF2 can not be used as pre-amp or an stand alone DAC. If you are going to spend $600 for an iBasso D10 plus an EF1 I would suggest you buy an used Oritek DAC V4.0 or higher w/ the built in headphone amp. This combo sells for about $500 and IMO is a better sounding option.
Jul 29, 2009 at 1:18 AM Post #129 of 1,326
I've got a pair of NOS/NIB SYLVANIA 6AK5 tubes on the way as my tube upgrade. I couldn't find the Raytheons. Will the Sylvanias be OK? Thanks, Chris.
Jul 29, 2009 at 8:10 PM Post #131 of 1,326
Originally Posted by koven /img/forum/go_quote.gif
I just also purchased a pair of NOS 6AK5 tubes off ebay for about $14.xx shipped
Should I change them out immediately or do you think I should give the stock tubes a try?
Give the stock tubes a try and burn-it in with the stock ones.
Jul 30, 2009 at 12:00 AM Post #132 of 1,326
Nice review Larry.
I'm looking for a nice desktop amp to use with my IEMs
Do you get any hum with the ES3X with the EF1/EF2? Which one would be better suited for IEM usage?
Jul 30, 2009 at 3:34 AM Post #133 of 1,326
Originally Posted by Ricey20 /img/forum/go_quote.gif
Nice review Larry.
I was very clear in my review about what I heard - if I didn't mention hum I didn't hear any, and I used IEM and full size phones with it.
I also said that the EF1 volume control was unsuitable for IEM while the EF2 volume control works well with them.
Aug 1, 2009 at 1:42 PM Post #135 of 1,326
Hello EF2 users,
I'm currently using the Sennheiser HD 25-1 II and the Sennheiser HD 595 in combination with the Ibasso D2. When I'm using the DAC in combination with the HD 595 I'm not really getting a lot of bass. Will the EF2 give a better representation of the lower frequencies on my HD 595 in comparison to the D2? Proper amplification could solve this problem doesn't it?
Thanks
