Originally Posted by sithlord32786 /img/forum/go_quote.gif
Thanks for the input.
Well, if I got a better DAC like the D2+ or D4, I wouldn't really need to get the EF2 then. In that case I could get a different amp and just pair the amp and DAC together. The only reason I was really attracted to the EF2 was because it was an all-in-one solution, but if the DAC in the iBasso's are really that much better than the integrated DAC in the EF2 then I just might have to get one of those and then a tube amp by itself. I could then use the iBasso for portable purposes. The only problem is that now I'm spending even more money that I would have with just the EF2, but I guess, you get what you pay for.
Sounds good - the thing I like about the EF2 is it's balanced sound and more power than a portable, for the cost of a portable, but with desktop quality sound. What I don't like is that some people assume that if they wont use the DAC then it isn't worth buying, when I still think it is hard to beat as a tube hybrid for under $200. Others (that I have heard) to consider are the EF1 (or it's replacement, the EF5), Cavalli CTH, Millett Starving Student. I've not heard the LD amps.
I find the EF2 has a precise enough volume pot to use with IEM, as did the CTH that wiatrob built and let me review. The Cavalli is great if you can build your own amp, and is very tunable with 6.3v and 12.6v tubes. The one I tried had a nice volume pot. The EF1 was very good and only slightly behind the CTH, but good enough that I sold my DV336i after I got the EF1. It is more powerful than the EF2 and responds to tube rolling as well. The EF1 volume control was not as precise and was not good for IEM, but I understand that has been corrected in newer versions while mine was made very early in production. I actually traded the EF1 for the EF2 because I liked it so much. Our Millett SSH from the rds kits has the same issue with an imprecise volume pot, making ours a poor choice for IEM, but as a DIY amp you can choose a better volume pot if you need.
Obviously there are a lot of desktop amps in this $200-400 price range to consider, including SS like Travagans and Firestone or Nuforce. But I still use my EF2 often with my Macbook and Pico DAC, even though I could restrict myself to only my most expensive amps. If you can't DIY and can't spend $600 on a Woo amp, I tend to think of the EF1 and EF2 as my preferred recommendations. The Qinpu A-3 is another one I reviewed and like about as much, especially for driving Stax transformers.
