Thanks for the quick response. I forgot to say, I need an unbalanced cable, and a pin diameter of 0.78mm. I think the ones you listed are 0.75mm as they're made for the KZ ZSN?
I didn't have any issues with 0.75mm-0.78mm cables and IEMs. The only problem were FLC8s and their ~0.70mm sockets.
The important thing is if the type of 2pin plugs: flush or near flush, protruding, or encapsulated (ZSN type). Flush plugs work well with flush sockets, but also with ZSN type protruded sockets. Protruding plugs work well with recessed or flush sockets. Encapsulated (ZSN/QDC) plugs are only for protruding sockets (and you have to be careful, because the shape of the capsule, usually rounded, must be compatible withe the shape of the protruding sockets; for example, some TFZ IEMs use polygonal-rect protruding sockets which you'd have to sand off a bit to fit most ZSN/QDC rounded plugs).
@hakuzen I am looking for a sub 50$ (can add a bit more if absolutely needed) mmcx to 2.5mm balanced cable for my Sony XBA N3AP. Prefereably light weight. Can you suggest me one? I went through your posts but seriously confused. Is getting the cheaper one a good option?
Should I get no. 1, 2 or 3? TIA.
1.
6N OCC + OCC Silver plating 26AWG Special Offer from Electro Acousti
2.
GUCraftsman 5n OFC silver se535 se846
3.
NICEHCK High-end 8 Core Single Crystal Copper Silver Plated Cable
I've only tried number 3, and it is a good all-rounder.
But I tried this cable yesterday:
https://www.aliexpress.com/item/33004747860.html, and despite of quite higher resistance, I've been impressed with the low background noise and big stage (specially noticed in dense passages) for the price, and with the extreme softness and suppleness (although the sleeve is delicate, weak; you have to take care of this).
If your cable number 1 uses this wire, plus similar silver plated wire, it could be a great value. Plugs are very good. But can't confirm it till I try that exact cable.
Anyway, if you spend only a little more, you can get the chance to try best neotech 7N UP-OCC wires, which suppose a jump respect any other wires.
4 cores version of cables 170 (copper), 173 (silver99%gold1%), 175 (170-173 mix), 177 (copper+spc mixed into each core), or 172 (copper no-litz).
