niranhopper
- Oct 13, 2007
E7 + E9 + HD600
I'll re-post UncleEric's excellent reply to a similar thread asking about the best way to spend $1,200 on a rig. Take off the $600 speakers and it will be in your price range. I also listen to HD600 more than any other headphone I own, including RS-1 & D7000.
"$1,200?
I'd pick up the Magnepan MMG for $600 and spend $50 or so for an old receiver. $200 for a used Sennheiser HD-600, $300 for one of the new Dynalos, and whatever is left for a modest DAC.
You'd get a pretty damn good intro to speakers and headphones."
I haven't heard too many dacs/amps,
I would not spend more than $200 on a dac/amp combo. Spending $400 on dac/amp and $200 on headphones is just silly.
My D1 has had zero problem driving the K702s with very extensive bass. Headphones like the Ultrasone Pro 900 are very easy to drive as well, and any cheap amp should do fairly well. Again, spending over half your budget on amping is silly. The majority of your budget should be headphones.An HD650 is going to sound 10x better than an HD555, no matter how well the HD555 is amped.
I totally disagree - proper amping is essential. I would most definitely go $400 for a Dac/Amp and $200 for lets say the HD 600's.
Spending over half of your budget on amping is highly recommended.!
There seem to be a lot of "HD 6x0" recommendations - are these really that good?
My setup came to just a bit more than $600 retail. But check out the FS forum, that's where everyone on a budget should start.
seconded i was originally going for the sparrow tho however for an extra 100 you can replace op amps and use the amp as a preamp which saves u in the long run
Originally Posted by olor1n /img/forum/go_quote.gif
With a tight budget, I'd go the NFB-12/11/Sparrow + HD600. This is based on the assumption the "lesser" Audio-GD combos are somewhat comparable to the Fun (minus the opamp rolling) and the HD600 is as good as it's made out to be. If you can stretch the budget to obtain gear to last in the longer term, I'd recommend the HD650 + Fun with at least the Earth and Moon hdams. Both configurations sound great and will allow you to tailor the sound to your preference.
Thanks for all of the inputs guys - I really appreciate it. It seems like the Audio-GD products and the Sennheiser HD 6x0's are very good choices. I will definitely take them into consideration.
However, I have often found - especially with the IE8, that Sennheiser products aren't necessarily bad, but not that great value. You get what you pay for, but not really anything more. Although it seems like the 600 and up are very good contenders in their price ranges - am I right about this?
In full-size headphones there is immense value with the 600s or 650s (YMMV with European prices). I think there is enough literature on head-fi for me to omit further elaboration. Don't compare the value of the IE8 with these cans, it's a whole different arena. In my experience, after the re-zeros, more or less everything in the IEM market has had some serious diminishing returns.
As for the above post, the $520 MSRP HD600s are routinely sold on Head-fi for about $230. HD650s ($650 MSRP) for $270. I bought my HD650s from an authorized dealer brand new for $320 including shipping, OP you may be able to get them to ship international.
