FURTHER MODIFICATIONS
- Punch hole mod
You open the back of your MS1 (best method is warming it with up before, by means of a hairdryer from
sideways) so that you get access to the rear side of the driver. You'll see that it's covered with some black fleece stuff. Now you take a pencil or something similar and punch 4 holes into the fleece.
The result is an increase of the bass amount, especially the kick bass section. I do not recommend more than 4 holes, unless if you are a severe basshead. That mod is only suited for the smaller models having the plastic sound chamber as to be seen on the pic above (MS1, MS2, SR60-325), do not do it with higher tier models (MS Pro, RS1 etc.) as you'll end up in a rumbling midfi mess!
- Pad coating
It turned out that coating of the inner parts does not only increase the
comfort (I personally find the foam a bit scratchy). It also has a similar (but better) effect to undesired brightness as putting felt or fleece thingies on or in the distancer. In difference to that fleece- or felt thingies, you don't put a barrier in the way, hence bass amount and detailling do not get damaged. In addition, you'll get much more
warmth into the overall sound sig.
Material of the coating and its ability still to provide sufficient breathing matters though. It's a fine line with the pad lining between the smooth and "real" sound it brings and it slipping over in to muffled and too thick a sound. NoXter & me had the best results with ordinary T-shirt textile material, you may experiement a bit before the final fixation. A provisorical fixation of the test pattern may be done by means of needles, final fixation may be done with ordinary paper glue.
I personally haven't tried it, but I guess by means of pad coating it will be possible to do the MS1000 with the shriller models (MS2, SR325, etc.) as well, as its effect can be really mighty, dependend from choice of coating material.
Allover, the punch-hole-mod and the pad coating are a very nice bundle. You'll get 98% of the nicer MS-Pro "Ultimate" tonality when applying both modifications together. Not the sheer resolution and blackness though, there's still a gap between the 99$ and the 700$ model...
