I've found that the generic G pads are more large on-ears with a fairly shallow "cup" and the OEM Gs are more over-ear.
Very well put, and accurate. Thanks for the reply.
Are you sure that it´s driver that is broken? It could be cable as well. And thats very easy and cheap to fix.Hi, question for you people. My original GS1000 left driver blew. I guess they're pretty old. I wrote to grado asking for a replacement but got no reply. As mine had a black dragon cable mod on them I figured Grado wouldn't help anyway, so ordered a set of V8 which are now on their way.
...and so this morning I got a reply from Grado saying they would replace them. The cost is the same as the V8s.
As I'm not sure if Grado will still honor the replacement if I dig the original drivers out to test - is it worth spending more on the Grado drivers or should I give the V8s a spin? I've not read any comparisons of the v8 vs gs1000 or or seen any threads of anyone else replacing them.
Didn't you have to remove the drivers to install the black dragon cable? Also, you might have to re-install the original Grado cable before they will do a repair from what I encountered so far getting a SR325 gold repaired since they wanted it in stock condition before doing any work on them, it was a flat fee of $75 + shipping to them. They replaced both drivers even if only one was dead and changed the original 4 conductor cable to the newer 8 conductor one that started to come on SR225e and up and they included a new gimbal to replace one that had a broken pin.Hi, question for you people. My original GS1000 left driver blew. I guess they're pretty old. I wrote to grado asking for a replacement but got no reply. As mine had a black dragon cable mod on them I figured Grado wouldn't help anyway, so ordered a set of V8 which are now on their way.
This is a modded SR325 that I use SMC jacks on and a few pictures of a SR60 showing the inner workingsCould anyone refer me to a guide I can use so I can mod my SR 325's with mono plugs & jacks?
Put the V8 drivers in this
https://www.aliexpress.com/item/32811989313/32811989313.html
I’m considering buying that just to hear it. It’s €45 on sale haha.
I asked the seller so we shall see what the diameter of the driver is in this thing.Dang! If a V8 would fit in that, what a bargain!
