Shoewreck
@DavidA , please let me know if my assumption was true.
I suddently found slanting cups to be a good idea. Tried 6 mm on top, 8 mm on bottom, but 8mm seems better to me.not even all around
What about going 8mm on the back side and 6mm on the front, like how some drivers (HD800/700) are angled so the sound is more into your ears?I suddently found slanting cups to be a good idea. Tried 6 mm on top, 8 mm on bottom, but 8mm seems better to me.
I'm feeling slightly ashamed of not measuring the depth prior to disassembly. I hope somebody would measure a set of lower end Grados just to find if they're tuned differently. I did readjust SR-80 cups with similar resuts, but it was long ago and no measurements were made back then as well.
You are so right, I was thinking of my old SennGrado where I did try to angle the drivers within the cups, LOL.@DavidA , cushions are symmetrical and gymbals rotate freely, so driver position won't change. You're free to experiment however. Probably pushing the cup further out would result in even better results, just make sure it doesn' fall apart while you're in public.
You could try one of the alternate drivers from Nhoord, Symphones, or Elleven Acoustica. Might need some work to fit the these drivers or just get the one of the drivers and some wood cupsSpeaking of SennGrado, my sr60s have been sitting in my drawer for over a year now because I took the headband+cupholders to make SennGrados. Anyone have any easy ideas for a headband+cupholder for Grados?
Not sure I understand, I need this... (or an alternative)You could try one of the alternate drivers from Nhoord, Symphones, or Elleven Acoustica. Might need some work to fit the these drivers out just get the one of the drivers and some wood cups
This is what I did to my SR-225e:
Added dynamat in the outer sleeve and felt disk on back of button, dynamat on the back of the driver:
Opened up one extra vent hole on each driver
Since then made removable cables using SMC connectors and MDR-7506 headband and cheap G pads:
Great idea, only thing that stops me from doing this is most premade cables don't use decent quality wires and many times they are coated so its a pain to work with.When im modding headphones, (what i do a lot!) i go to local music, or electronic store, and choose proper readymade cable, like mini, or normal plug
->RCA or such, and clip connectors from another end, and voila, you got yourself very decent and pro grade cable, with no hussle.
Not a direct answer to your question but have you tired either L or G pads? For me the S or 414 pads are just too uncomfortable and while the L pads (generic or OEM) are a bit better for comfort they are much better sounding IMO. I like the generic G pads from ebay ($4-6) best for comfort, and they also give a 1-2dB boost to the bass and I find the imaging/sound stage to also be slightly better.What is the best dye to use with the Senn 414 pads? I'd love to dye them red to match with the custom cups I have made.
Also how much differences is there in sound between TTVJ flat pads and quarter modded Senn 414 or S-cush?
