elmoe
Formerly known as JashuganHeadphoneus Supremus
Well if they worked fine with the punch hole mod before then that cant be the issue. The only thing left is soldering.
Thanks for the input everyone. @fleasbaby sorry for not following through with the cups, I'm still stuck modding my 225is as you know.![]()
Also what would be the best way to clean/remove the solder?
About recabling the 225s: do you guys think it's ok to do it without desoldering the standard thicker cable? I.E. by simply living a few millimeters of the existing ones and soldering the new ones to them?
Incidentally: how would I recable the 225s as they have 4 conductors per channel?
Thanks!!
Little question about Grado button removal on 225s: do I have to open the cans before using the hairdryer or can i just do it from the "outside" of the grill without damaging the driver?
Thanks!
Thanks!
