P4 the Warbler a new portable amp from iBasso . . first impression pg 3 . images Pg 6&7 . . .
post-9138026
Post #481 of 561
Huxley
Interesting, added to my list for when my hours pick up.
Got my OPA627's and i've fallen for those, that's again with the 5002's and bypass ground.
Quick question if you will, are these fine in my P4, i ordered them without 100% knowing if they're fine.
http://www.ebay.co.uk/itm/260318493270?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Also can you use buffers and opamps in either ground and L/R channels, or are there some combinations to be avoided?
post-9138912
Post #482 of 561
MusicalChillies
Previously known as Sinth.
Using the 627`s in L/R? Never tried it but then again I haven`t bypassed ground. Will try that combo over the weekend. Problem is though as I have mentioned I need the 634`s as buffers because to me, they are the kiddies that add the bass punch instead of the 5002`s.
Edit: that is in my P3 though, the P4 may perform really differently.
post-9140422
Post #483 of 561
jamato8
I really like the 5002. The pin out is different from the standard op amps and buf634 so the surface mount need to be ordered and the adapter socket used like the one from Brown Dog, which corrects the pinout for using in the socket.
post-9141939
Post #484 of 561
SpudHarris
Hey John, long time no see/speak. How are you doing my friend?
I have been testing Ryuzoh's Maxxed MB Dac recently, wow, that is some piece of kit.... I have already told him to put me on the list for the new one which will be I-device type as he has a licence from Apple now.
post-9146068
Post #485 of 561
jamato8
Doing fine here in Alaska. The MB1 dac is a great little dac. Excellent sound and fun to use, I agree. Haven't heard the maxxed version. If word really got out about it, it would be a smash hit.
post-9174059
Post #486 of 561
Angular Mo
anyone with a P4 that has recently purchased a Fiio E12 Mont Blanc amp?
I am interested in how they compare to one another as I own the P4, but am interested in the Fiio E12.
post-9215267
Post #487 of 561
putente
Here's a question to the P4 experts...
I'm currently using my P4 with the following setup: OPA627BP x2 + HA5002 Buffer x2 + Dummy Ground x2
I like it very much that way, but I really never tried other opamp configurations, as this is how I got it from the previous owner. If I wanted to make it sound as close as possible to a tube amp ("warmest" sounding possible, mostly), which opamp configuration should I look for?
Thanks.
post-9215958
Post #488 of 561
SpudHarris
High end tube sound generally tends to be warm and smooth but with no loss of micro detail or dynamics. There are warmer sounding chips but many sacrifice these things. The only one I found to come close to high end tube sound was the LME49990, it's still a chip at the end of the day and never going to sound exactly like a tube amp as design and power play a big part in that. It's a nice chip though in the P4. I have used them with HA5002 buffers and ISL5002 in ground for as long as I can remember.
Regards - Nigel
post-9215998
Post #489 of 561
putente
Regards - Nigel
Thanks, Nigel!
I'll get the LME49990! I've found several on eBay in DIP8 format, but I'm not sure which ones to get for the P4! There are versions with 2 LME49990 in a single DIP8 and others in 2x DIP8 each with a single LME49990... Help, please?!?
Also, where can I find those ISL5002?
post-9216337
Post #490 of 561
SpudHarris
This is where I bought all mine.....
LME49990
The ISL5002 are a little tricky to get as they come on a special adapter with resistors on the base. I bought mine from Ron Kerlin (HiFlight). He is my OpAmp Guru and an absolute gent, I'm sure he will sort you out if you drop him a line.
Hope the link above works, I've not done this on the iPad before.
Best of luck.
post-9216348
Post #491 of 561
putente
LME49990
Best of luck.
Yes, it works, thanks! So, I'll need to get 2 of those LME49990's from that link to use with the P4, right?
post-9216384
Post #492 of 561
SpudHarris
Just one needed for P4. They have a chip top and bottom making it a dual OpAmp.
post-9216422
Post #493 of 561
putente
Thanks! Sorry for all the questions, but I know very little about opamps...
The same seller also sells it in 2x singles (here), ence my confusion.
post-9216434
Post #494 of 561
SpudHarris
No worries pal, how you gonna learn if you don't ask questions. Most of the guys here and on the OpAmp thread will be happy to help. Just let us know how it goes.....
Cheers
post-9218603
Post #495 of 561
putente
Well, since I need to learn more about opamps, can you further explain the difference between those two LME49990 versions available from that seller? I mean, if I were to buy without asking you first, I'd go for the 2x single instead of the 1x dual! From what I can understand from the P4 manual, it can take both options (1x dual or 2x single) or am I wrong? Are there advantages/disadvantages from one option to the other?
Thank you for your help!
