Originally Posted by ujamerstand
...So to make sure my understanding is correct, the small driver of the SFI means that it is unable to produce a lot of bass because it is unable to move a lot of air.
It's able to move
enough air to produce bass because its diaphragm isn't constrained in the middle-- it can "dome" up and move a good bit of air, as long as you treat this air pressure as precious and conserve every last bit of it while not making the driver try to move too many molecules, ie, you keep the volume enclosed by the earcup to a minimum, as in the Pro 30, Stax SR-X, Stax SR-30, Audio-Technica ATH-7, etc, which all represent a good compromise between an airtight seal on the ear (tough to do with a supra-aural pad of a reasonable size without inducing pain-- but see also the T20v2) and bass.
Remember, people are getting what they claim is real bass (and I have no reason to doubt them) from a 35mm square driver, which is only 8% larger than the SFI.
To solve this problem a reflective plane can be added to the back.
At this point we're in danger of combining two techniques which are separate. The mfrs found that the reflective plane added to the
treble output, which was otherwise disappointingly weak.
In a ported speaker, you try to utilize the woofer's backwave by inverting its phase and adding it to the frontwave, but in the typical ortho, we're basically throwing away the backwave, using some of it to produce antiphase seasoning which helps the sound escape our skulls. Real world, we're not able to delay the backwave enough to produce a full phase inversion, so we can't really use it to augment the frontwave (except, as Sambones says, at certain discrete frequencies and even then, not very much) but at least we can keep it from eating the frontwave's bass.
Awhile back, I facetiously suggested using flexible tubing to lead the backwave down from your ears to your shoes and releasing it there. Call it the Bass Drain.
Thus, by summing of the "out of phase" backwave information and the "frontwave", you can produce bass for a small driver like SFI.
The backwave is already maximally out of phase, remember, so we tweak it to be not-so-out-of-phase. That way, combining the front and back isn't quite so bass-deadly as it would otherwise certainly be. Even the YHD Yamahas, which use a driver not unlike the SFI, can produce bass without pads or anything more than a vestigial cup. Even so, Yamaha had to cheat (by underdamping the bass) to get the bass level up, so there's bass, just not very good bass.
Your SFI transplant had bass trouble at first because there was the headphone equivalent of a car's vacuum leak. The leak was bigger than the "magic size" hole Smeggy established by experiment; ergo, your bass was
wasted, man. Now that you've sealed that leak, you should have bass if your pads are reasonably flat like the ones on the Pro 30 and company, and if the backwave has to wind its way through an acoustic delay line (damped vent or SmeggiPort) on its way to the atmosphere.
I just regret that I might have gotten a better one. Oh well, I made a promise to myself never to spend over $500 on a single headphone ever again.
The regret you feel is ever the regret of the headphone addict chasing the state of the art. It is one of the outer circles of hell.
Promising yourself a limit of $500 is a pretty good promise.
Originally Posted by smeggy /img/forum/go_quote.gif
I am so getting a set of audeze, even if it kills me.
Originally Posted by antonyfirst /img/forum/go_quote.gif
I will be dying to read your comparison.
Originally Posted by Kabeer /img/forum/go_quote.gif
Oh Tony, Im dying to hear YOUR comparison when you get the LCD2..
All dying! and them so young! These, then, must be KILLER headphones, arrr.
