Originally Posted by gurubhai /img/forum/go_quote.gif
I tried the DT880 velour pads on my T20v2 today. They fit nicely but unfortunately all bass disappeared(probably even less than the stock form). Curiously, the headstage appeared to have widened a bit.I ended up removing them pretty quickly
@BMF : Can you tell me what effect does the O2 pad have on the T20 sound.
On other note, I got hold of some better felt today & revised the mod. The bass is very satisfying now. Now If only these stock pads didn't hurt my ears, I probably won't take them off my head.
p.s. I am not getting any resonances with my pair.
Did you try the inside out stock pads?
Your dampening scheme will have to change.
The O2 pads act as a bass lens, limit the volume of the ear pad that the driver has to fill, and move the ears farther away from the driver thereby making them sound brighter. The leather also seals better than the stock pad so they will sound a little more closed too, but it's offset by the treble extension so it's not as bad as thinner pads.
My theory on the resonances isn't so set in stone and I haven't really sat down to study acoustic physics, yet, but the cup size difference definitely effects the mids and highs slightly, enough that I bet the resonance peak shifts up out of the upper midbass/lower midrange and into the upper mids or low highs. the cup size certainly has a much larger effect on the bass, but since we're dampening the drivers anyway, it's not as large an influence as undamped drivers in larger cups.
That said, IMHO, for small driver orthos like the Yamahas and small Fostex, I think the solid leather pads like the O2 pads are a great benefit, but on the big boy drivers like the T50v0 and T50v1s, a suede pad helps tremendously. SO much so that I may sacrifice my O2 pads to the seam ripper to get the pattern pieces for suede versions. Hmmm... red suede pads and headband anyone? Nah, natural brown or slate gray for me.
