Originally Posted by dBel84 /img/forum/go_quote.gif
On a different note, I just noticed that the HP50 driver uses similar beveling as did PMB
who woulda thunk ..dB
edit
a close up of the driver membrane
and another
so that pict's took from the HP50A driver or Sony DR11 of mine ?
Originally Posted by Kabeer /img/forum/go_quote.gif
Great find dBel, to further that note. The HP-3 has similar sloping holes. The YH-100 and 1000 dont.
I don't know what this all means though.
Now, iQem, im not sure where your friend found those Sony DR-11, but I am going to think it's not an ortho. DAC said he wasnt convinced so I looked at it further. And I believe that someone just glued HP50 drivers into a DR-11 enclosure.
Sony DR11 - Wikiphonia
Looking at your pics, the glue job is very messy. Also the baffle has holes OUTSIDE the driver edges, indicating there was once a larger driver there.
The suprise at how it had a ortho driver in it due to its completely different chassis than a normal planar, was probably because its a dynamic can. The yellow version you link to says 8 Ohm on it (i dunno if yours says so). I don think the Yamaha drivers inside were 8 ohm right?
This begs the question, what nutjob thought it wise to put HP50 drivers in there :S?
maybe but at the first time i open that DR11, it's glued perfectly to the baffles (with hot glue, offcourse)...
all the hot glue covered the grill holes that out of the driver diametre...
it's messy when i opened the driver from baffles to get replace...
but if you & DAC think that it's not basically an Ortho, then i'll remove it right away from the Wiki Ortho until i figure out that the DR11 are really an ortho...
as i had said before on earlier posts, a friend of mine find that DR11 on local antique store with both channel died...
so i bought it from him and found that one driver are dead, and the other are just cable problem...
even if the drivers look the same to HP50 driver, i had test&compare em' both...
they sound different, i use the same source, same cable without any enclosure and holding em' by hand...
but maybe it's just my ears, who knows...
Originally Posted by wualta /img/forum/go_quote.gif
Well, even if it was never a real ortho model, iQEM's is an ortho now. Problem is, it's dead. I'm hoping Don PM'd all his secret manipulations to iQEM so he can spread the orthohealing methods to his part of the world.
amen...
Well if it isnt an ortho it needs to be removed from the ortho list (on the wiki). That was the main reason for my post.
I think the holes are conocal. It seems the inner hole (next to the disaphragm) is smaller than the outer hole. And the hole edges arent smooth (if thats what you meant by chamfered).
what's wrong with the Wiki Ortho ? someone maybe had hacked it...please take a look...
well the doc may have some skills but he was sent into paroxysms when these showed up yesterday
The mail was not good to iQEM's drivers , all is not lost though, we have some potential of getting at least the YH100 and HP50 back up and running. I was pleased to hear the YHD3 went to him
As far as the T10 is concerned - I tried a few things, the auzie disc up against the diaphragm, stock glass fibre biscuit and 2/3 donut worked the best to my ears. It is still a work in progress but this is the latest incarnation and I have been happy with it thus far..dB
yup, 1pc of HP50A & 1pc of DR11 magnet are broken...the HP50A are with the broken-but-glued magnet before i send em to db, but both DR11 drivers are in good shape before the shipment...i might claim the expedition but for what reason ? there's so much trouble...
Originally Posted by scompton /img/forum/go_quote.gif
That's some serious damage. Were the magnets already cracked?
I don't remember seeing Aussie felt mentioned before. How dense is it?
nope, there in one piece before the shipping...but...nevermind... *sigh*
I think one may have been broken but the other happened in transit
Auzzie felt from our felt fiend Ludo 1 and & 2.
..dB
agree...but even it's broken the magnet of that HP50A had been glued together before...
iQEM, we feel your pain.
If the busted magnets broke clean and there are no ferrite crumbs, I'd think good ol' CA glue should do the job. Not that I'd want to volunteer. I'd want to borrow some PMB magnet clips to help hold it together, too, despite those clips being a PITA.
thank's for the input, wualta...
