^ I placed some approx. 90mm round hybrid pads on top of stock pads. 90mm too large, needs maybe 75mm. Ive only tried them with stock pads.:
The Akai ASE-40 reminds me a lot of Fostex T10 and Yamaha YH-1 in terms of form and sound. The Akai is a lot smaller and lighter than expected. Metal parts are used but they are thin and the headband is very minimal which when combined with a light clamp is very comfy in comparison to T10 or T30 and comparable to YH-1. The tonal response and detail retrieval is right around T10 and YH-1 levels as well. I'm trying to be conservative on judging detail retrieval because Akai has a slight peak around 10kHz which is probably causing these to sound more resolving than they actually are... Fortunately, this 10kHz peak and apparent resonance is not fatiguing nor sounding smeared, cymbals sound extra clear and defined without being harsh. Listening to music without cymbals or other high frequencies is closer to the experience of listening to T10 or YH1.
I've not checked specs but I'm guessing the drivers are about the same size as T10 or YH1. As you can see in the pics these have pads that cover up much of the driver's face. I wonder how these would sound padrolled. That driver face grill is definitely not ideal either. From memory, the bass is nowhere near T30 or RP18. I wonder how @Feilong4 's Victor D90 relative sounds in comparison. The D90 afaik is just a double-sided magnet version of ASE-40 driver. Do you have pics Feilong4?
Please see the video I linked to a few posts above to see this headphone disassembled. There doesn't seem to be much space inside for damping materials. If I disassemble later it will be mainly to clean the driver face grill holes to get the most out of padrolling.
The rear grills have vents placed probably exactly where the driver's magnet holes are positioned making these headphones effectively open back at least in comparison to T10 or YH-1. I do get the impression that these are more open sounding but again I wonder how much is due to that small 10kHz peak.
I like them. Remind me most of T10 which I liked as well but comfort was holy hell! These meanwhile are possibly more comfy than YH1 with similar relatively good tonal balance.
