So I bought a pair of TDS-15's. I wanted to revisit these, I remember them sounding pretty good. I remember saying that they are worth having in your collection due to bass quality and urethane diaphragm, they had a smoothness to them.
I got them, plopped them on my head, and yee gods they did not sound good. I was like "It's these pads," so I removed the drivers from housings and spun them around. I tried to shove stock pads into the housings just to hold the drivers, but didn't really work. Then I stuck stock YH-1 pads onto the rears of the drivers which were now ear side. Sounded so much clearer. I took measurements of this configuration:
Whoa. Bass hump. They don't sound bassier than YH-1's. I have bass boost ALWAYS ON on my receiver so both headphones receiving bass boost and YH-1's easily more bassy, imho. But after reverting everything back to stock and sealing the YH-1 pads with damplifier pro, they sounded pretty darn good to me. I wanted to hear these drivers in a full circumaural enclosure. I bought a Sennheiser HD555. These have baffles angled at 9 degrees. I figured the angled baffle would give soundstage, but alas, the enclosure is too small for giant 70mm vintage planars... So I still had an HD535 laying around. I was trying to sell the refurbished 535, but there's zero interest in vintage Sennheisers apparently, haha. So chop them up for science...
Dremel cut rough 70mm holes, friction set drivers into baffles, then sealed around the drivers and all the baffle holes with damplifier pro. Akasa paxmate covers baffle faces where pads do not cover to kill reflections. This was supposed to be temporary mod, but Idek. They show potential.... but they are not YH-1 level even, imho, and they are already more expensive. Do I swap magnets and hope for more detail? What if these got RP-18 detail level with neo magnets? Does anyone know what a magnet swap usually does to the sound? Higher sensitivity? More bass? More detail? All of the above? Like what HAPPENS? I really wanna buy custom magnets for the hell of it just to SEE. If anyone reads this and has any idea what a magnet swap might do for these headphones, please chime in, I'd really like to know.
This is the measurements of TDS-15 // HD535:
Haha, they are called Russian Thanos headphones because the first TDS-15 that I purchased years ago had a Gold diaphragm circuit and a purple driver housing piece. One of my friends called them Thanos headphones because of the color scheme and it stuck.
They sound like really good consumer headphones now. Bass isn't as impressive to me this go around, it's just normal bass mostly, but there is a haze at times and I wonder if this is bass oddities. Detail isn't amazing, just high enough that you get a sense that the drivers are very capable, but they don't cut as deep into the track as even YH-1's. I really thought bass would extend lower after circumaural enclosure, I sorta chalked it up to supraural pads not sealing on EARS and was hopeful for more, but obviously not the case... I couldn't angle the drivers, either. I was going to just leave the drivers cocked in the baffles while they were friction set and cement them in with damplifier, but the ear pads have plastic rings that cover up the drivers and inhibit any angle. Can't really mod pads to support angled drivers, either, would destroy them, so they are just.... normal headphones. Sad.
I listen to them and I'm like, "These are really good," and then I listen to YH-1's and it's like, "Oh... Well these are better..." So sad. I just recabled them with stock YH-1 cable so now it's easy to put your noggin' into them, haha, the stock HD535 cable didn't have long enough Y-split portion so it was weird. I think they're done, unless someone chimes in and says they will be T50 killers with neo magnets. Driver is 70mm, movable membrane maybe 60mm at widest section? Serpentine circuit. It could be really good with neo magnets?
