MDR30
- Sep 8, 2009
Just to avoid confusion, the colour refers to the plastic, not the metal traces, so the driver on the photo is the kapton version.
Well, this is not the case. Definitely, there is no strong bass... just weak weak bass... I'd say the AKG Q701 drivers produce very strong bass compared to PMB 80.
The combination of deep powerful bass with airy highs is one of the finest characteristics of the PMB series
I'd say there is a very good chance that the bass is all there still, just cancelled out by the backwave at the moment. The combination of deep powerful bass with airy highs is one of the finest characteristics of the PMB series - but it takes some experimentation to bring it out.
I 'found the bass' when I took the naked drivers out of U70 and held them up ONTO my ears.
Find a way to keep them there comfortably and you'll probably win some sort of headphone nobel prize equivalent for sure.
Apparently these are not as good as the higher end PMB drivers but I experienced the same effect as others report.
Replacing the old white earpads with pleathers is also a good place to start.
... in case anyone else would like to try it out - the key is as mentioned to hold the drivers comfortable onto the ears. This modification goes against all conventional modification rules - it does not rely on sealing the driver to the baffle. Instead, it relies on having an exceptionally short distance between the driver and the ear, thus avoiding bass cancellation from the back wave.
The solution is really very simple, just mount the driver on the outside of the baffle. Then place (deep enough) circumaural pads on top. Use e.g. blutack to position the driver comfortably.
Thanks. I understand. But doing this involves a radical mod to the unit, doesn't it? I would prefer to keep the original look too. For instance, this unit has white pads (original as the PMB80 was NOS, sealed box) and they are quite thin. But the box shows a pleather pad.
GREQ says that using pleather could be a way to start. German Maestro sells pleather pads and I know they go perfectly well on PMB80. Or is the modification you wrote about the only way the PMB80 would show more bass?
I know that the Wharfedale ID1 manual advises to tap it directly off speakers terminals and that Hifiman sell a box to do exactly that but is anyone seriously used to do this?
I mean most vintage orthos take extreme gain to coax serious bass and I just scored several full discrete stereo AVR's so I though I'd give it a shot but I'd rather not toast my orthos huh, IIRC Fostex talk about a 3W max wattage on their T50RP so I would guess that all should be well?
One of them is from Onkyo and claims to run a full balanced internal design, sounds like a plan
I'm also used to only plug my phones once the headamp is on and unplug them before turning them off, this would be a no-go with the speakers kludge if I don't bother building an Hifiman-like box but I think some of them got anti-pop relays so that should be fine.
Some boutique manufacturers claim that their headamps are so beefy that they could drive speakers, the hell with it then ^^
